E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Loosing coolant.
I own a 2001 325i. It looses antifreeze frequently, basically adding a bit more every 2-3 days. I know there is a blue bleed screw under the car driver side close to radiator. Can this be a gasket issue or something else. Like fixing things my self just need tips. The leak seems to be close to that bleed screw...
Very probably your expansion tank.
Plan to replace it and maybe do a cooling system overhaul if due. Leak there can be hard to see. |
I would start by checking the upper radiator hoses for cracks. Then look for signs of coolant - when the coolant evaporates, it leaves a white residue.
The expansion tank is usually a prime suspect. I posted a similar thread a couple of days ago, in my case it turned out it was the expansion tank. Very sneaky little leak. Search for the thread if you want. |
