1998 BMW 740il overheats - Bimmerfest - BMW Forums
Old 10-06-2012, 07:53 AM
tripleo750li tripleo750li is offline
Mein Auto: 2006 BMW 750li
I recently found a 1998 BMW 740il for extremely cheap. I'm considering purchasing it but it overheats. Can anyone assist me in what might cause this and a possible fix? I know possibly the thermostat or pump but just in case thats not the only problem suggestions would be greatly appreciated. Thank you in advance.
Sent from my DROID RAZR using Bimmer App
Old 10-06-2012, 09:43 PM
gotrice415 gotrice415 is offline
Mein Auto: M3, 335Ci, X5d, 750i
Could be a pandoras box. If its a deal that sounds too good to be true it may have warped heads and or blown head gaskets. If you're lucky could be leaking valley pan. Hard to say without looking at it. If you live in the SF bay area PM.
Good luck!
Old 10-06-2012, 10:58 PM
BMWFatherFigure's Avatar
Old School
Thermo fan: fan clutch; blocked/contaminated radiator; air in cooling system plus all the other stuff. Hope it's REALLY cheap.
Current:
E38 Parts Car
Previous:
Old 10-11-2012, 05:07 AM
Oh yes it is, still debating on purchasing though. Thank you for all the advice and tips
Old 10-12-2012, 09:40 PM
Old School
So - Did you buy it?
Current:
E38 Parts Car
Previous:
Old 10-12-2012, 10:47 PM
setconstr setconstr is offline
Mein Auto: 2001 740i spt 2008 cl550
re
I should just keep a copy of this but I'll tell you for the small investment of taking it to a Indie shop and having it checked out you can save thousands in repair costs so do it and be sure, these cars can be awesome but also can be the largest can of worms you have ever seen....
Old 10-15-2012, 06:28 AM
Haven't purchased yet, actually pulled back to do routine maintenance on my 750. Trans fluid change, tune up and next brakes. Will be taking one of my SA's over to kinda push us in the right direction of either purchasing or leaving it alone.
HTML code is Off
