E36 (1991 - 1999)
Old 10-06-2012, 07:11 PM
peels'bimmer's Avatar
peels'bimmer peels'bimmer is offline
LSD = yum yum
Send a message via MSN to peels'bimmer
Mein Auto: '95 332IS
Removing rear control arms/camber arms
Need some help! I'm in the process of removing my rear control arms on my e36. The top bolt is hitting the diff and won't fully come out. My questions are; do I have to remove the diff to get this bolt out? Can I just lower the diff to get enough clearance? If I can get by, from just lowering the diff. Do I have to remove it from the drive shaft or can I just remove the 3 bolts that hold the diff in place???
Originally Posted by TRaV MaNN View Post
you never notice how ugly something is until you get rid of it
That's what my first wife said.
Old 10-06-2012, 09:01 PM
hornhospital's Avatar
D'oh, You Kids!
Just take the diff mounting bolts out of the carrier but don't take the diff out, You can then slide it around enough for the bolts to clear. Be careful putting the diff bolts back it. They are VERY easy to cross-thread.
Quotes to live by:
BMW-CCA #441426
Old 10-07-2012, 04:11 AM
LSD = yum yum
So leave it connected to the drive shaft, but, remove the 3 bolts holding it up?
Old 10-08-2012, 10:10 AM
Amanzimtoti Amanzimtoti is offline
Mein Auto: BMW e36 316i
Just removed my control arm, had to remove the diff bolts and with a bit of a wriggle it came out. Going to replace it tomorrow hopefully without stress and advice tips or tricks would be appreciated.
Old 10-08-2012, 02:45 PM
LSD = yum yum
I just took my old ones out today too. Started to put my new ones, but, got called in to work. . If you've already got the bolts out. There's not much more advice you need. The only thing I could suggest would be, to check the bushings on the diff, lower control arm bushing and trailer arms. Of course, after you install the new arms, go get an alignment.
