E90/E91/E92/E93 (2006 - 2013)
Old 10-06-2012, 07:51 PM
Blackberry328 Blackberry328 is offline
Mein Auto: 09 328i 6MT Cabrio
Beware of idrive battery drain
I noticed every once in a while that Blackberry would be slow to start. I took her into dealer for battery check and some other maintenance as she's coming up on 50K miles. They found that while at rest...she was being woken up way too many times due to the controller for the idrive causing excessive battery drain. They replaced the con module and the battery and everything is ok now. I didn't even know the idrive controller was supposed to light up.
OAN...when I went to pick her up I test drove a 2011 M3 E93....OMG!
The blacker the berry the sweeter the juice!
Old 10-07-2012, 04:19 AM
Thunder Dump's Avatar
Thunder Dump Thunder Dump is offline
Tastes like chicken
Mein Auto: '09 328i E93 SGM/CR
You can help this problem by locking her while she sleeps, even if you park in a secure home garage. When the car is not locked it will stay awake longer than if it is locked, thus draining the battery more.
Old 10-07-2012, 04:27 AM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
+ 1 locked even in the garage!
Black Sapphire Metallic 18" ASA wheels Staggered Setup 12.5 Spacer Rears Increased Top Speed limiter Convenience Nav Harman RPI Scoop ZPP, ZSP, ZVP, 2XA
Old 10-07-2012, 08:59 AM
Thanks Thunder!! I'll definitely make that a new habit. I'm guilty of not doing that in the garage.
Old 10-07-2012, 12:20 PM
Lufthansa Lufthansa is offline
Mein Auto: 2010 E92; '07Lexus GS350
I have my doubts this observation would be the case if the car, like mine, had the factory alarm system.
Old 10-07-2012, 12:43 PM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 335is Cab & '08 535xi
The factory alarm system was the culprit of this issue on my wife's '08 535xi.
