Air Quality - Smells like engine oil breather is connected to Interior Air Filter?! - Bimmerfest - BMW Forums
Old 10-07-2012, 10:22 AM
ZAR2USA ZAR2USA is offline
Mein Auto: 328i
I tried different settings, Auto Recycle, Recycle, Off. No difference.
Long trips are unbearable. I constantly have to lower the windows to get fresh air inside.
Any ideas of what can cause this, others had issues with this before? Appreciate feedback.
Old 10-07-2012, 12:36 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Busted PCV line just might do it.
Have you tried taking it in for maintenance?
Old 10-07-2012, 06:33 PM
fun2drive's Avatar
BMWCCA 149159
If you smell oil you are either burning it by leaking it on the headers or it is heating up from other areas. The valve covers on this model BMW will leak. I would suggest checking to see if that is the case if the PVC or CCV is not the issue...
Old 10-07-2012, 11:56 PM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
are you running aftermarket air cooler?
Normaly this is the result of using a aftermarket air cooler and then leaving the PCV valve open instead of putting it into a catch can.
Also check your Oil filter housing see if you have any seepage
