E30 (1982 - 1993)
5 speed whining
Hey guys got the 5 speed swap completed. But there is a wine that sounds like its coming from the transmission, every gear could it be low on fluid? No grinds or anything out of place what could this be?
did you check/change the fluid before you put it in?
im guessing the whining wasnt there before the swap?
i had a whining noise in my tranny. grant it my 1st gear synco was shot, but even with new fluid still made the noise.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
No I didn't =( stupidly lol. Its not first its every gear I'm kicking myself in the a$$ for putting a used throw out bearing in. It makes a howling noise without my foot on the clutch, I'm thinking that is my problem.
I also re used my csb from the auto Buut I spent every dollar I had on all necessary parts for the swap and went in with little knowledge so I guess that was my mistake being to impatient but income taxes are soon so my e30s christmas will be coming early. Taking her to the body shop and getting every knick and dent fixed then getting her resprayed factory swartz then iridium plugs, new wires, cap, rotor, timing belt, valve adjustment, etc. So I'll just add a full trans service in that equation Last edited by BmwMan92; 10-05-2012 at 12:57 AM. |
pop the fill plug out and see what the color of the fluid is. if its the typical colors, internals are fine and most likely throw out bearing, if its silvery, youll be looking at a tranny rebuild or a better tranny
Its clear green or yellow
Make the throw-out clear the clutch for a test and see if the noise goes away. Then press the pedal and see if the noise comes back. Bearing change here we come...................
Yes throw out bearing is bad lol so is that my problem?
Oh my that's quite a job to throw old used parts back in. My $$ is on the bad TO and a lame input shaft bearing or pilot ,or all 3 bad is the most likely scenario.
Pilot its new
TO or input shaft brgs. All out and start again. Another chance to get the engine bay clean and tidy.............
Didn't pull the engine
Oh you opted for the easy way eh?
![]() So much easier to pull/drop IMO.
Yeah I didn't want to pull the engine. But I'm regretting it now (tore engine mounts).
Sorry that happended to you but still not to bad - engine mounts are cheap. I think that even the OEM's are under $30 eachGood Luck
Life's Good! 07 Z4Si - Mods: M front Bumper, Mstache, Alarm, Hardtop Retrofit & Hardtop, mudflaps, windscreen, DaveZ GDO, Intravee II, Gaptech Remote +, Diet hamburgers and a Fat steering wheel. 03 330i - Mods: MTechII front Bumper, 125K and rollin! |
