How do I verify If I have factory sport suspension?
I am the original owner of a 2002 BMW 330i and I need to order new struts/shocks. I special ordered this car from my dealer. I really wanted the two door model but to keep peace with the family I ordered a four door model with 5 speed manual transmission. I also ordered the the cold weather, premium and sport packages - which I thought included sport suspension. I still have the detailed window sticker that was on the car at delivery and it clearly lists my packages and under the "Standard Features" heading it lists among other items:
"Strut-type front sport suspension with forged aluminum lower arms" and "Multi-link rear sport suspension with cast aluminum upper transverse arms" I want to make sure I order the correct struts for my car since sport and standard are different lenghts. To verify that I have the sport suspension I had my dealership review my VIN (WBAEV53402KM02124) as well as a few parts suppliers. To my surprise all stated that I had the standard suspension. So between the window sticker listing and the VIN, I don't know what type of suspension I have. Short of taking my car to the dealer, is there any way to visually confirm that I have standard vs. sport suspension? |
There are other things too, but they don't always tell the tale. Round airbag steering wheel is one way to tell as is sport seats and the 5 spoke ///M badged wheels. |
I have the sport package which includes the M (5) double spoke alloy wheels, performance tires, adjustable front sport seats, aerodynamic package and leather sport steering wheel. These are all listed under the Sport Package listing. As I mentioned earlier, "sport suspension" is listed under Standard Features. |
If you have the sport pkg then you have sport suspension.
Jeff R. Golden Gate Chapter BMW CCA - Autocross - Come Join Us! ![]() "You drive like old people $#@%... slow and sloppy!" - George Carlin |
Ref my initial post on this thread, why can"t the dealer and a few retailers determine this from my VIN? They ask for the last 7 characters of the VIN and it always crosses to standard suspension. I am thinking BMW assigned the VIN to a four door sedan then modified maybe changed to a sport suspension per my special order. Could my VIN not have the correct suspension code form the factory?
Could not make out the X numbers on either rear shock. I did a parts search with the first number and nothing came up. |
As per instructio s in the Bentley Manual, measuring from the bottom edge of the rim to the bottom edge of the fender, for 17" wheels front should be 589 mm, rear should be 554 mm. For 18" wheels front should be 602 mm, rear should be 567 mm. For a car without broken springs, maximum deviation should be 10 mm.
http://www.facebook.com/home.php?sk=...?id=1338939628 "I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride" |
I don't know if it pertains to 2002 models (seems likely, given the label on the car from the factory), but in 2005 at least, the 330i came STANDARD with the sport suspension (just like the 325ci/330ci), with or without the sport package. The 325i came standard with the non-sport suspension, unless ordered with the sport package.
Even goofier, the 325xi/330xi didn't have the sport suspension even if they have the sport package.
From the WIKI...
Changes for March 2001 Production
325i and 325iT:
325Ci and 325Cic:
330i:
330Ci and 330Cic:
I am within 4.8mm in the front; Rear is off by 22.3mm. What do you think? |
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
Looks like you have standard suspension. I say that because you stated your part number is 235267xxxx when it actually is 33526757045.
I looked up your car in REAL.oem....http://www.realoem.com/bmw/showparts...41&hg=33&fg=45 They list the part number of strut/shocks for both standard and sport....for your car the sport rear shock part number is:33522282461...standard suspension rear shock # is : 33526757045 Standard strut part number is: 31306757043 Sport strut part number is: 31312282459 Last edited by QAfred; 10-07-2012 at 06:28 PM. |
sport rear shock part number is:33522282461...not even close to what you thought you read Last edited by QAfred; 10-07-2012 at 06:28 PM. |
I believe you just cracked the code and I didn't see because of the way the numbers where laid out on the shock and a bit unreadable. I does look like it cross to the standard suspension.
Yes, I believe so.
The above WIKI quote/info stating 330ci from 3/2001 all have sport suspension must not be accurate. I say that because I have a 2001, 330ci ZSP, Mfd in 6/2001, with sport seats, 17" staggerd M wheels (7.5" in the front, 8.5" in the rear) round horn button etc. and the part number on my shocks were the standard part number also. I put the orange Koni's (Str t's) on them two years, 20,000 miles ago and I am happy with them. |
"Strut-type front sport suspension with forged aluminum lower arms" and "Multi-link rear sport suspension with cast aluminum upper transverse arms" Sport package does not mean Sport Suspension is included. |
correct....we have sport package but apparently not sport suspension.
I think we also needed to have the "Sports suspension settings S226A package"...as stated in realoem...to get the sport struts/shocks.
Have you replaced your struts and shocks yet? If so, what brand did you select?
yes, you missed it....I stated above that, I put the orange Koni's (Str t's) on them two years, 20,000 miles ago and I am happy with them.
Did you consider Koni FSD's?
#25
yes, I did. As I remember they say they are soft when you are cruising and stiff when you need it etc....well, when I am cruising on a highway I did not understand why I would want a softer ride? I want stiff on my 330ci all the time and they are. Anyway, I called the Koni rep and he stated the orange koni's are the same strut as the yellow koni, just not adjustable...i.e. they are set to a "nominal" setting....just watching Smolck adjust them yellows made me happy with my decision.
...getting too old for that *hit....made my elbows sore just watching him ![]() I wish I would have put Billstein touring or Koni FSD's on my wife's 323i however. I think the Koni STR T's are too stiff for it /our sedan...but it has 212 k on it and probably will let her go in 3 years or so, when I get my new Silverado paid off. I am holding the wife off as long as I can because, of course, she wants a new Bimmer...I want to retire next November...not sure who will win. I hope to get her to settle for a 2013 CPO in 2015/16? ...unless she really cries like this.The 330ci; I plan to keep at least 10 more years. I have changed motor mounts, tranny mounts, RTAB's, dif bushing recently and just put Michelin Super sport summer tires on it too (thank you Florida) and this thing runs/tracks better than the day I bought it in 2004. |
