E90/E91/E92/E93 (2006 - 2013)
CEL emissions issue with Akropovic Exhaust
Anyone have any issues with the Check Engine Light coming on and staying on due to "increased emissions" and Akropovic Exhaust? I have brand new e92 (less than 300 miles) and put titanium exhaust on it. CEL has come on and idrive says increased emissions.
Any ideas on how to fix/prevent? |
Caused by CAT delete or insufficient O2 sensor ports. http://www.europeanautosource.com/pr...pressor-e9x-m3
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer / no chrome WHEELS FOR SALE
If you have an N54 back pressure is critical for waste gate/turbo operation since the flap is actuated in exhaust.
the op has a different issue. Sent from my Galaxy Nexus using Bimmer App |
So if you dont do that what do you think the DME does? Sets a fault for activation and vacuum leak causes lean mixture faults. Last edited by gotrice415; 10-07-2012 at 12:50 PM. |
The flap on the tailpipe is for noise regulations only, blocking of the vacuum line has no effect on anything at all (won't even throw a code and certainly has nothing on earth to do with emissions). Wastegates are on the turbos, not the exhaust flapper at the end of the tailpipe. Wastegates are vacuum controlled also (only thing you have correct) to control the volume of exhaust gas driving the turbines. The DME measures the difference in pollution on the primary cats, there is a sensor before and after, 2 cats on the N54's, 1 on the N55's. Secondary cats are not monitored by the DME. Now back to the actual question - Op lists that he has an M3, so no turbo's. My guess that something was damaged when the exhaust was installed, either wiring to the O2 sensors or an O2 sensor itself if they needed to be removed to install the exhaust - the car is seeing too much of a difference across the primary cats. M3 also has dual primaries with an O2 before and after, there should be no issue with the install going anywhere near those, so either the had to much with something up front or it is just a coincidence. Rob
2008 335i Vert Montego/Saddle/Grey Poplar 2014 X3 35i Space Grey/Chestnut/Fineline Wave Last edited by roadkillrob; 10-07-2012 at 01:48 PM. |
Kimi
leaving the vac hose unplugged will NOT set an emissions fault or cause any kind of lean/rich condition... Sent from my Galaxy Nexus using Bimmer App
Past: 2001 330i ZSP/ZPP/Step Past: 2004 S60R 6MT Sport Past: 2007 335i 6MT ZSP/ZCW/322/655 Past: 2010 335xi ZMP/ZCW/ZPP/PPK/PE Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Current Homeland Threat Level: Last edited by Orient330iNYC; 10-07-2012 at 01:52 PM. |
But hey, congratulations on flippin' your lid over trying to argue over the internet. Next time try getting the right subject, though, eh lad?
