E90/E91/E92/E93 (2006 - 2013)
Old 10-07-2012, 07:55 AM
reltney5150 reltney5150 is offline
Mein Auto: 2013 M3
CEL emissions issue with Akropovic Exhaust
Anyone have any issues with the Check Engine Light coming on and staying on due to "increased emissions" and Akropovic Exhaust? I have brand new e92 (less than 300 miles) and put titanium exhaust on it. CEL has come on and idrive says increased emissions.
Any ideas on how to fix/prevent?
Old 10-07-2012, 08:36 AM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
Caused by CAT delete or insufficient O2 sensor ports. http://www.europeanautosource.com/pr...pressor-e9x-m3
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer / no chrome
WHEELS FOR SALE
Old 10-07-2012, 09:28 AM
gotrice415 gotrice415 is offline
Mein Auto: M3, 335Ci, X5d, 750i
If you have an N54 back pressure is critical for waste gate/turbo operation since the flap is actuated in exhaust.
Old 10-07-2012, 10:21 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
this is not accurate. i have the oem performance exhaust, installed at the vdc and there is no exhaust flap. there is a stub to terminate the vac line. the valve is for low rpm noise reduction.
the op has a different issue.
Sent from my Galaxy Nexus using Bimmer App
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 10-07-2012, 12:08 PM
CT's Avatar
CT CT is offline
GODSPD
This is exactly correct. The flap operation is purely for noise reduction at low throttle and low RPM due to European regulations. Back pressure is handled entirely through the design of the flow path itself.
WHEELS FOR SALE
Old 10-07-2012, 12:43 PM
Ok so you just said it youself. How is that not accurate? There are dpdw's that control the wastegate which is vacuum to it. Since you have an exhaust installed by VDC im sure they blocked off the vacuum line and retrofitted the DME software to ignore or not activate the flap since it ha been deleted.
So if you dont do that what do you think the DME does? Sets a fault for activation and vacuum leak causes lean mixture faults.
Old 10-07-2012, 01:46 PM
roadkillrob roadkillrob is online now
Mein Auto: 325CIC, 335CIC
Do you have any idea what you are talking about???????????????
The flap on the tailpipe is for noise regulations only, blocking of the vacuum line has no effect on anything at all (won't even throw a code and certainly has nothing on earth to do with emissions).
Wastegates are on the turbos, not the exhaust flapper at the end of the tailpipe. Wastegates are vacuum controlled also (only thing you have correct) to control the volume of exhaust gas driving the turbines.
The DME measures the difference in pollution on the primary cats, there is a sensor before and after, 2 cats on the N54's, 1 on the N55's. Secondary cats are not monitored by the DME.
Now back to the actual question - Op lists that he has an M3, so no turbo's. My guess that something was damaged when the exhaust was installed, either wiring to the O2 sensors or an O2 sensor itself if they needed to be removed to install the exhaust - the car is seeing too much of a difference across the primary cats. M3 also has dual primaries with an O2 before and after, there should be no issue with the install going anywhere near those, so either the had to much with something up front or it is just a coincidence.
Rob
2008 335i Vert Montego/Saddle/Grey Poplar
2014 X3 35i Space Grey/Chestnut/Fineline Wave
Old 10-07-2012, 01:50 PM
Kimi
the exhaust valve flapper malfunction does not set a cel. if you unplug the flapper at the solenoid you throw a silent code in the dme indicating an open circuit. if you leave it unplugged there is no code as the component is not an emissions component. if you read the post by ct, the exhaust the op installed is catless, which will throw an emissions error code as there are no cats. the flap has nothing to do with emissions.
leaving the vac hose unplugged will NOT set an emissions fault or cause any kind of lean/rich condition...
Old 10-07-2012, 03:17 PM
Kimi
Wow, where does engine vacuum come from? I only do this day in day out for a living at a dealership. Yes you are right that the flap is meant for noise reduction. But how about you take a look at documentation on when and why the flap would open. So your tellin me that if you induce a vacuum leak it wont throw a code or cause a lean mixture issue? How about you test that theory and leave your oil filler cap off or disconnect a vacuum line under the hood. Vacuum is created by the engine with low pressure differential. With N54's there is a vacuum pump since adequate vacuum cant be established at higher rpms. Do a few drive cycles and let me know what you find.
Old 10-07-2012, 05:18 PM
CT's Avatar
CT CT is offline
GODSPD
Wrong vacuum location. There's a vacuum-operated flap in the left-rear exhaust pipe just aft of the muffler. Has absolutely zero effect on engine back pressure or vacuum. Don't overheat there, buddy.
But hey, congratulations on flippin' your lid over trying to argue over the internet. Next time try getting the right subject, though, eh lad?
WHEELS FOR SALE
