CAN bus time out - code d9 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 10-07-2012, 03:22 PM
C Sean Watts C Sean Watts is offline
That'll buff right out
Mein Auto: '97 328is, etc.
I had to remove then replace the DME (and other control unit with it) and now I have a d9 code - CAN bus time out.
NO- check engine light or ABS light
YES- ASC light will not turn off and transmission warning light is now on. I KNOW the trans is good.
ANY IDEAS if this can be reset with a Peak tool?
If you anagram Julian Assange you get "Alien Anus Jags."
Old 10-07-2012, 04:04 PM
dc_wright's Avatar
bimmerfest Supporting Member
Try disconnecting and reseating the connector on the DME and the "other module" . Those connectors can be difficult to get fully seated and locked down. When you have them disconnected look carefully at the connector pins on both connectors and make certain you don't have a bent pin(s).
Old 10-07-2012, 05:31 PM
It's dark now but I'll give it a try tomorrow.
OH- Is there a minimum time I should leave the battery disconnected BEFORE touching the computers?
Old 10-08-2012, 12:11 PM
DC had it...
Update and BACK date:
I posted a year or so ago about a 'coil failure, cyl. no. 1" failure. I kept getting mil. light and pulled the code with a Peak -- "11 1d EE" I swapped out coils among cylinders - code came back. Changed the coils when Bav Auto had them on sale - code came back after two weeks. I had the injectors cleaned and tested OFF the car and they were a bit lean but not totally out of spec. - code came back after a month or so. I changed the PCV ducts, oil separator, etc. AND changed spark plugs - code came back after a few days.
Fast forward...nothing indicated bad valves or rod AND once in a while the 'check engine' light will go OFF, on a warm, dry day.....HMMM. I'm onto something. SO I found and opened the computer compartment. FULL of 14 years of road dust, leaf powder and bug wings. Whatever tiny hole the crap came through let plenty in! I EVEN FOUND CRAP INSIDE THE TRANS COMPUTER CONNECTOR!!!
I had some CRC electronic cleaner and Deoxit - and plenty of patience....I sprayed, tooth brushed gently and used the deoxit, then let it soak and blew it all clean with a can of air. Plugged in and started - GOOD NEWS...no lights. I have not test driven (raining and I'm cleaning up) AND only time will tell but so far so good after ~10 of running.
Old 10-08-2012, 12:25 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Yahoo! I hope you took some pictures? That might be one for the photo album.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 10-08-2012, 03:05 PM
NO, unfortunately, BUT I can get some of the foam cover in front of the computer compartment when it stops raining. There really wasn't much to it other than the dust in there.
