Old 10-07-2012, 02:10 PM
Boeing750i Boeing750i is offline
Mein Auto: 2007 750i
$7.77 a gallon!!!!???
Came across a gas station with 110 octane. Bad idea for our cars?
2007 BMW 750i Sport
Old 10-07-2012, 02:39 PM
Suri [TBR]'s Avatar
Suri [TBR] Suri [TBR] is offline
Mein Auto: '06 750Li
If you want to try it, empty out the tank and don't put in more than 2 gallons. It'll clean your fuel system out and it'll at least feel somewhat faster - even though adding high-octane gas in cars without forced induction doesn't usually show any marginal power gain.
"The Ultimate Driving Machine"
2006 BMW 750Li - Style 128's with Michelin Pilot Super Sports, Magnaflow quad exhaust, ACS Roof Spoiler, ACS Aluminum Pedals, Umnitza LED License Plate Lights, Beltronics V995
1997 BMW 540i - E39 M5 wheels, straight piped quad exhaust, CAI, Dinan performance chip, H&R springs
2002 Lexus LX470 - Window Tint (20%)
2012 Toyota Camry Hybrid LE - Window Tint (30% front, 15% rear), LED interior lighting
2006 Mercedes-Benz S500 - AMG Sports Package - SOLD
Old 10-07-2012, 03:04 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
I used it at the Sunoco over by the bucs stadium. Worked fine.
650i sport hud asanti af132
Old 10-07-2012, 04:44 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
The car will run a lot better on 110, but make sure it isn't boosted with ethanol (no more than 10% in the 110 octane) otherwise your car will not run well! Most 110 is 100% gas so it's always good!
If you run 110 in your car, you shouldn't hurt it but it might be wasting a bit of money since the gains you get are marginal and decrease as you increase in octane past 100. I'd suggest filling up with maybe 23 dollars worth on a half tank, that should give you 3 gallons of 110 and 12 of 91-93 averaging out to 95-97 octane (depending on what you started with)
Old 10-07-2012, 05:59 PM
Thank you guys. I am not too concerned with increasing power. More curious if this is a solid way of cleaning the involved components.
2007 BMW 750i Sport
Old 10-07-2012, 06:16 PM
I put 50 bucks worth in.
Old 10-07-2012, 06:33 PM
csmeance's Avatar
Mein Auto: 760Li
Octane won't lead to cleaning much of anything for the most part, the cleaning really comes from the motor running a tad better and theoretically you driving it harder thus you break pieces of dirt/dust off while driving (Italian tune-up). You in all honesty will need to use a good fuel in the first place to avoid buildup, and use a PEA based fuel cleaner like Techron or Redline SI-1
Old 10-07-2012, 06:55 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
My friend runs 8 gallons a month in his car. He says it keeps the system clean.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-08-2012, 08:44 AM
061k 061k is offline
Mein Auto: 05 bmw 745li
For cleaning you should go with a good fuel treatment, and premium 93, 110 will not make a different that is worth the money on a 7, and you have to make sure that 110 is unleaded some race fuels are not and damage you oxygen sensor with time
Old 10-09-2012, 11:01 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
i havent tried 110 octane yet
Old 10-09-2012, 05:12 PM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Higher octane is required for higher compression engines....running it in your 7 is a waste of money.
2007 Kawasaki Ninja ZX-14
2006 BMW 750i
1972 Dodge Charger
1968 Dodge Charger
1967 Austin Healey Sprite
Old 10-09-2012, 05:48 PM
leewtech leewtech is offline
Gone for a drive.
Mein Auto: BMW, GM, Fountain
Total waste of money if your motor is not designed or required to use it (check you owners manual). Detergent is mandated in all gas by the federal government. Some brands may use a tad more in their own formula but it is a negligible difference. It's all marketing folks....don't fall for it.
Use what your car is designed to use, buy it fresh, and keep your motor in good repair. That's the magic.
Old 10-09-2012, 11:59 PM
Suri [TBR]'s Avatar
Originally Posted by Tangystuffin View Post
your signature is 10 times longer then your posts. whats up with that
Is there something wrong with that?
