How do I disconnect this wire? - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 10-07-2012, 07:47 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Airbag-euipped steering wheel. There's a wire that goes from the steering column to the back of the steering wheel - how do I disconnect it from the steering wheel? For some reason it doesn't feel like it should pull straight out. Maybe I am being too gentle with it?
I Timothy 2:1-2
Old 10-07-2012, 08:02 PM
BMWFatherFigure's Avatar
Old School
Diconnect battery and go have a looooong coffee. I think that wire is the airbag trigger and will disconnect from the airbag unit end. Battery disconnect to allow units to discharge fully.
Current:
E38 Parts Car
Previous:
Old 10-07-2012, 09:10 PM
an audience of One
The battery had been disconnected for eight hours prior
Anyone?
I Timothy 2:1-2
Old 10-07-2012, 09:17 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
that is an airbag wire, you need to disconnect that orange plug you see under the column in the picture.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 10-08-2012, 01:02 PM
an audience of One
Thank you, Steve!
It looked to me like that wire went through the column - I didn't realize that orange connector had a little access panel below the column.
Just as an FYI, the airbag wheel weighs 9lbs, the MT 1 weighs 5lbs. Measured at the post office.
I Timothy 2:1-2
Old 10-10-2012, 04:57 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Wink Howlin with laughter
Code:
The 4# you lost there will drastically decrease your acceleration times
Never mind lowering the centre of gravity
Sorry, I could not resist
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 10-10-2012, 03:03 PM
an audience of One
Originally Posted by Nick323 View Post
Code:
From my seat position, the airbag wheel blocked the oil temp gauge. The solution was to install a MT 1, which I prefer anyway due to its minimalist, classic design. The weight savings was an additional benefit, taking 4 pounds off the steering column. I shared the info as an FYI, not as a reason to believe.
I Timothy 2:1-2
Old 10-10-2012, 04:32 PM
E30-325's Avatar
E30-325 E30-325 is offline
Mein Auto: BMW 325is
Mark, more pictures of the M3 please!!
Old 10-11-2012, 01:31 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
should have gone tech2!
E30 above Sold
Last updated 2nd January 2014
Old 10-11-2012, 06:31 AM
an audience of One
Yes, sir... working on it
I am not a fan of the MT II and am less a fan of the alcantara stuff. They just seem out of place in an E30. More suited to the E36
I Timothy 2:1-2
