Old 10-07-2012, 02:38 PM
md1_61 md1_61 is offline
Mein Auto: 2006 325CI
What not to do
I purchase this 2006 325CI with 128000 mile about 4 or 5 months ago. When I removed the oil filter housing cap the first oil change (the day I got it) I knew the PO had not taking care of oil changes. I have been changing the oil every 500 or so mile to try and clean her slowly. Well I had a small oil leak starting around the oil filter housing and this is what I found, I had cleaned the housing when the wife came out and took a few pictures.
ID:	344705   Click image for larger version
ID:	344706   Click image for larger version
Old 10-07-2012, 04:17 PM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
Hope your Vanos doesn't die soon after doing that. Go get some BG engine flush and run it, or sub out a quart or two of transmission fluid to get that sludge out
Old 10-07-2012, 10:12 PM
Mein Auto: '04 330Ci 6-speed
Feel for you running into an engine like that.
Just read that the myth of using trans fluid to clean out an engine is dangerous.
Never put anything other than oil in. Maybe with engine flush to idle with.
Old 10-08-2012, 05:16 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Not a myth. I've done it several times. The key is not to do anything more than idle.
Safer still is Lubro Moly's engine flush treatment. Comes in a kit for about $100 and if I was the OP I'd do it right away. Napa carries it.
Old 10-08-2012, 08:21 AM
spicytofu spicytofu is offline
Fungineer
Mein Auto: 2011 E92
seafoam?
Old 10-08-2012, 08:35 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
Originally Posted by spicytofu View Post
seafoam?
Seafoam is great stuff. Its not as complex as its hyped to be though, it is pretty much kerosene. If you have alot of miles pour half a bottle in the crankcase a few days before an oil change(unless you have a pretty long drive to work.) Then pour the rest in and let it idle I. The driveway with some revs Nd change oil. I've done this on every car once a year. Rub a little through the gas tank and into the vac lines. Great stuff to clean a motor.
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 10-08-2012, 01:19 PM
e46_platform e46_platform is offline
Mein Auto: 2002 330Ci 5M sport
that seems slightly different from what bob said before
here's the exact quote i recorded as a reference for myself to run the procedure eventually:
OP, how long have you owned this car? What was the oil consumption like in the past? If the problem isn`t with the CVV (the usual cause), then the oil-control rings (on the pistons) are likely not doing a great job, and the oil is being burned in the combustion chamber. This scenario is normally traceable back to inadequate break-in because of the use of synthetic oil during break-in, it doesn`t allow for enough friction to "scuff-in" the rings against the cylinder walls.There IS a possibility you can improve things by trying the following procedure:
When it`s time to change your oil (and when it`s a quart low), add a quart of ATF, and run the engine at fast idle (around 2000-2500 RPMs) for 15 or 20 minutes. Drain oil, install a new filter, and some good dino oil like Castrol GTX 10W-40. Run this oil for 3000 miles, and during this period, drive it *agressively*, running it up to redline frequently. After 3000 miles, change oil & filter, switching back to your normal synthetic oil, and see if you note any improvement.
Old 10-08-2012, 07:53 PM
Dr.BMW
Mein Auto: 2015 M4
One quart of atf will be diluted enough to not kill anything while revving it up.
