Old 10-07-2012, 07:51 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
Exclamation Must read for 540 owners! Possible catastrophic Power Steering failure
This had just been brought to my attention and never seen it mention here on the fest. Very important.
http://forums.bimmerforums.com/forum....php?t=1501053
Old 10-08-2012, 12:32 AM
Mein Auto: 1999 740i
Thanks for the tip. Guess Ill be checking my PS bolts tomorrow.
Old 10-08-2012, 08:11 AM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
Thanks for the info,Very good stuff here that could save you thousands!!!
Old 10-08-2012, 08:55 AM
Ed Cheung Ed Cheung is offline
Mein Auto: E39
So how do we check on the PS pump?
96 528i AT w/steptronic. => 97 540i w/ steptronic. =>steptronic deleted, 6MT installed.
Old 10-08-2012, 09:51 AM
jmanyoyoyo jmanyoyoyo is offline
JDM killer
Mein Auto: '03 540 m
People so need to read this. It happend to me aswell and the total cost for me was $700.
Sent from my SPH-M820-BST using Bimmer App
Old 10-08-2012, 12:37 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Are we talking hose bolts or ps pump attachment bolt to engine. What would be some symptoms?
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 10-08-2012, 03:30 PM
JDM killer
For me it was the ps welds, they snapped and cracked the ps pump in 2 places. I knew it was the ps at frist by the "nails on a chalk board" sound when turning then the next day I heard a loud snap at the welds busted and some belt snapped simutaniously.
With 124,000 miles I decided to do the highly discussed cooling system overhaul aswell.
In all I replaced
1) ps pump and hoses
2) fan clutch
3) a belt (don't rember wich)
4) radiator with hoses
Old 10-08-2012, 06:02 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
I pulled up this DIY from a few years back - it will show you what to look for. Probably belongs in the stickies (and maybe it is already). I wish I lived next door to a rocket engine welder.
http://www.bimmerfest.com/forums/sho...d.php?t=323318
BMWCCA#401441
Old 10-08-2012, 11:12 PM
DinanBimmer's Avatar
DinanBimmer DinanBimmer is offline
Mein Auto: 1998 540i 6-speed/2003 M5
I'll be checking my PS pump this weekend, thanks for the heads up 540indiana!
Supersprint X-pipe attached to Dinan Free Flow Exhaust, m tri-color black kidney grills, 20% tinting on back windows, LED Angel Eyes, HID Fogs, and much more to come.
Old 10-08-2012, 11:45 PM
senser senser is offline
Mein Auto: 540i/6 E39
Dang! Seeing threads about this stresses me out! I'll check it first thing in the morning.
Old 10-09-2012, 12:25 AM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
So I read through the linked threads. I don't fully understand the problem. Is it the bolts backing out and causing the brackets to break? Or are the brackets weak and just breaking off?
Old 10-11-2012, 10:50 AM
540indiana's Avatar
From what I understand, the bolts are backing out and the stress from turning the car could cause the brackets to break.
I just know that I waas happy to have found this thread. I checked mine and all the bolts have not moved. I would prefer to get it on a lift so I can get a better view of the pump.
Old 10-11-2012, 01:45 PM
Thanks indiana. That was my first guess also. Will check them this weekend.
Old 11-01-2012, 09:59 AM
lawyer540 lawyer540 is offline
Mein Auto: '02 540i
Yes. And it happened to me yesterday. I had owned my '02 540 for 4 years now (daily driver) and had no idea this was an issue until I just did a search and found this thread. I stopped for gas and went I started my car back up and drove off I noticed the steering was extremly hard to turn and the battery light was on. I was just a mile from the dealer anyway so I said oh well and was going to drive there. Then I noticed the temp gauge was going to far to the right, so I pulled over and shut her down. Then I noticed the belt hanging below the engine under the car (I don't have the splash guard on - but I need to put it back). Right then my heart sank as I began to think oh crap, what have I done! My mind flooded with those horror stories of catastrophic failures under the hood! How the belt managed to not wrap up on anything....well I guess for once I was very lucky!
I had AAA tow it down to the dealer. Dealer called a few hours later and said the PS bolt had backed out, which caused the bracket to break. The fix is replace the PS pump and bolt.
So yes, if you have a 540 and are reading this - check that bolt!
Old 11-01-2012, 10:06 AM
540indiana's Avatar
Wow sorry to hear that man. This isssue haunts me more than the other ticking bomb on our car,
Old 11-01-2012, 12:08 PM
Reefin' Dude Reefin' Dude is offline
Mein Auto: 02 540it
after doing my oil change i removed the splash guard and checked my bolts. the lower one was loose, the upper one was fine. the lower was not super loos, but i could easily give it close to a half turn before becoming solid. i will check these bolts every oil change from now on.
G~
Old 11-01-2012, 12:34 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Along with the bolts backing out (haven't had that problem) if your water cooled alternator starts to seize up the tension on the PS pump from the belt can also rip the PS pump mounting tabs off the pump.
2000 540/6 Slightly tweeked...everywhere
Old 11-01-2012, 11:49 PM
540indiana's Avatar
Thanks Jim! That makes a lot more sense.
540 power steering leak hose
