Old 09-17-2012, 08:26 AM
rdc8118 rdc8118 is offline
Mein Auto: 2008 X3 sport
Replacing steering angle sensor
Here's the steps I took to replace my steering angle sensor. Do so at your own
risk. I'm not a mechanic.
The process took about half an hour. My DSC light was on, so I scanned the
codes and got a 90 degree difference of wiper too large steering angle sensor
error. The error wouldn't clear and always came back.
The first step was to remove the lower drivers side dash and floor panel.
I forgot to take pics of this, I'll see if I can add them later.
The next step is to crawl underneath the dash and look up. You'll see the
coupler that joins the two steering columns together. Mark where the coupler
joint is with respect to the steering column shaft attached to the steering
wheel. If you don't your steering wheel could be at a slight angle when you put
it back together.
Undo the nut and bold that clamps the coupler to the shaft. Grab the lower
shaft and push it into the floor (on it's axis). It will push into the socket
shaft on the floor.
Take a note how the steering angle sensor is situated. Unplug the steering angle
sensor and slide it of the shaft.
I took my steering angle sensor apart and removed the spindle. I noticed that
one of the sweeper arms on the spindle was broken or worn down (careful
they're fragile). This most likely explained the 90 degree error.
I picked up a working steering angle sensor from the junk yard, swapped out
the spindle and re-assembled mine. I figured this would save the coding step.
I slid the fixed steering angle sensor back on the shaft, plugged it in and
pulled the two steering shafts together noting where I previously marked them.
Put the nut and bolt back in and tightened it. Plugged in the laptop, clear the
codes and took it for a spin.
The 90 degree error went away and now I had a plausibility error. I ran a lew
adaption. Started the car and while slowly rolling forward turned the wheel
fully in one direction then the other. Took the car out for a spin, dcs light
stayed off and no errors. I took out the steering shaft coupler nut, added some
locktite before re-tightening the nut then assembled the lower dash. I've put
2000 klm on the car since then and no DSC issues.
On a side note it took me longer to remove/replace the lower dash then it did to
separate the two steering shafts, remove/replace the steering angle sensor.
I didn't need to remove the steering wheel or drop the whole steering column.
ID:	342194   Click image for larger version
ID:	342195   Click image for larger version
ID:	342196   Click image for larger version
ID:	342197   Click image for larger version
ID:	342199   Click image for larger version
ID:	342200   Click image for larger version
ID:	342201   Click image for larger version
Old 09-17-2012, 08:48 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Good write-up. Thanks for sharing.
Old 09-17-2012, 09:43 AM
SeanPhang SeanPhang is offline
Mein Auto: 02' 530iA@158k
good write-up. the previous owner spent $540 doing this on my car at an indy-shop.
06/10: rear shocks
08/11: cooling overhaul, O2 sensors
09/11: auto transmission drain & refill
09/12: alternator, VANOS seals, differential oil change
04/13: 2nd auto transmission drain & refill, changed fuel filter
12/13: OFH gasket
05/14: Aux. fan
09/14: CCV
Old 09-17-2012, 10:17 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
learned something new today.
thx for sharing.
now im glad my car's not equiped w/ that contraption.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 09-17-2012, 10:39 AM
cn90 cn90 is offline
1+,
I have a 1998 528i too. DHoang, are you sure your and my 1998 528i do not have that Steering Angle Sensor?
Old 09-17-2012, 11:53 AM
doru's Avatar
1+,
Item #9 in realoem
Old 09-17-2012, 12:14 PM
Well,
Realoem says #9 is for "vehicles equipped with DSC".
Mine has "ASC".
Old 09-17-2012, 05:24 PM
While the ABS trifecta DIYs have sections on the steering angle sensor, I looked in the bestlinks for /steering angle F3 and found nothing.
So I'll add this so others find it in the future, long after we're gone:
- How to test and replace the steering angle sensor (1)
TEST STEERING ANGLE SENSOR:
Note: The steering angle sensor, mounted at the bottom of the steering column near the flexible coupling, utilizes two potentiometers to determine the steering angle and the rate of steering angle change, which are are the two raw signals the CAN bus microprocessor utilizes to create the steering angle signal for broadcast over the CAN bus. The DSC III logic compares the stored plausibility of the steering angle sensor against other DSC III inputs (front wheel speeds, rotation rate and lateral acceleration sensors).
Old 09-18-2012, 03:36 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
cool thread , thanks for sharing !
I removed my lower dash one day and it took like 30 min
So you are saying that to remove lower dash is no more complicated than to remove steering shaft ?
Also no need to remove the steering wheel or drop the whole steering column
Interesting ... this makes this job very attractive
I am also wandering if there are any bearings in steering shaft which can be replaced at the same time
so you basically can get a car with a new steering feeling like a factory
Old 09-18-2012, 06:35 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
I once took a look at this thing and said how the hell you supposed to remove it??? Glad I didn't have too.
Great thread, and thank you for sharing..
Old 09-26-2012, 11:07 AM
jtperkins jtperkins is offline
Motown Tom
Mein Auto: 2001 525i/auto Silver/Blk
Cool DSC Light
My DSC light came on and stayed on about two years ago. On a rainy day I discovered that the anti-slip feature was not functioning when I spun the tires at a light. Other than that I've experienced no performance problems.
I took it to the dealer for diagnostics and nearly choked on my cup of Starbucks when the service guy quoted me $4,000+ to repair the "steering angle sensor". I passed on the offer and they charged me $125 for their time! Vampires!
I fixed the chronic light problem with a 1" piece of electrician's tape on the dash panel in front of the light. Seriously.
Can a real fix of this problem be as simple as you describe? Amazing!
Thanks.
Old 09-26-2012, 03:07 PM
DSC can save your life
Old 10-08-2012, 08:01 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Seriously
It can also kill you.
Old 12-14-2012, 01:08 PM
nezarnuaimat nezarnuaimat is offline
Mein Auto: X5 E53
Very helpful, thanks
Old 12-14-2012, 05:32 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
+1 Outstanding write-up. I'm glad you cleared up the difference between the steer angle sensor and what I call the "YAW" sensor. You can tell me if I have the terminology correct. There is a potentiometer of sorts that connects to a linkage (at least on my 540) that is then mounted with a half-ass clamp (that looks like a hose clamp) that secures the bottom of the shaft to passenger-side lower control arm. There are two flat spots in the control arm to help in orienting the bottom of the linkage. This is what I call the YAW sensor and I don't know if they are unique to DSC cars compared to ASC cars.
Does this fall into your area of expertise as well? Want to make sure I call things by the right name....or at least what we all call 'em here! Excellent write-up. Needs to be a sticky for sure.
Old 12-14-2012, 06:48 PM
Fudman's Avatar
Fudman Fudman is offline
Bill:
The Yaw sensor you refer to is the headlamp leveling sensor. I think it is only on HID headlamp cars. Mine is mounted to the passenger side control arm.
Old 02-08-2014, 03:03 PM
rakeshv rakeshv is offline
Mein Auto: 2001 540i Sport Wagon
I am currently trying to get the steering angle sensor out to see if cleaning the wires etc will fix the issue with traction control not working on my car. The instructions could not have been simpler, however I am having a hell of a time with "Grab the lower shaft and push it into the floor" part. I have been trying to push it, but it does not budge (okay, I am not a big person, but still...). How much force did you have to exert to push the lower shaft into the socket shaft on the floor?
Here are a few pictures of the current disassembled state of the lower dash
Rakesh
Old 02-11-2014, 01:06 PM
rplecty rplecty is offline
Mein Auto: 740IL
Bump
Old 02-12-2014, 08:48 AM
have y disassemble steering rack from the lower shaft ?
there is one 12-13 MM bolt which connect both
Old 02-12-2014, 08:55 AM
Yes, I removed the 13mm bolt which was shown in the first picture of the OP (which was termed the coupler), and the hole in my first picture (next to the 43 marked) is after the bolt was removed. Did not see/notice any other 13mm bolt, but maybe there is one more that I need to remove.
Rakesh
Old 02-12-2014, 09:32 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
I had a look at the procedure written up in BMW's TIS document and that's the only bolt mentioned.
I'd venture few people with e39s have had to do this, so that's probably why you aren't getting much help.
I haven't done it either so I'm no help. I can see from the location that it's probably not easy to get your weight down on that lower shaft. If it were me, I'd probably try shaking the shaft a little as I tried pressing it into the floor.
I have no clue how -far in- the shaft is supposed to go, either, but I'd think just far enough to give you the space to slide the sensor down and out would be all that's needed.
Good luck. If you discover anything not mentioned in any of the write-ups, please share.
Old 02-12-2014, 12:15 PM
Thanks for the hint about shaking the shaft while pushing it down. Next time I get under there to try I will try that. I had briefly considered placing something on top of the bushing and gently hammering to see if it will break any stuck on lubricant or whatever is holding the two together. Since it is my daily driver and I need to go to work, I decided against it :P. I shall certainly follow up if I succeed in getting it out.
Old 02-23-2014, 03:32 PM
Had another go at it yesterday. I thought the issue may have been that the steering was at its lowest position (since I needed to removed the trim around steering as well as expose enough of the coupler bolt) which may have prevented the lower shaft from going any further down. However, even with the steering all the way up I could not get the coupler to come off the lower shaft. I moved the steering up and down a few times while trying to hold on to the lower shaft to see if that would disengage the coupler, but no luck. I briefly tried sticking in a flat head into the gap that the bolt tightens to see if could loosen it, but since it is aluminum all I succeeded in was denting the edges a bit.
It is looking like a job for the local indie mechanic
Old 12-04-2014, 07:31 PM
A similar question came up today on how to test the steering angle sensor ...
> E39 (1997 - 2003) > DSC/Steering Angle Sensor
See also this E46 detailed steering angle sensor DIY...
- E46 Steering Angle Sensor DIY.. finally.
ID:	503311   Click image for larger version
ID:	503312   Click image for larger version
ID:	503313   Click image for larger version
ID:	503314   Click image for larger version
ID:	503316   Click image for larger version
ID:	503317   Click image for larger version
ID:	503318   Click image for larger version
ID:	503319   Click image for larger version
ID:	503321   Click image for larger version
Old 03-22-2015, 01:45 PM
TurnzSr's Avatar
TurnzSr TurnzSr is offline
TurnzSr
Mein Auto: 2001 525iT
I have the new steering angle sensor in hand and am ready to make the change. Does the sensor need to be calibrated or matched to the car using software like INPA after it has been installed? I have read that turning the wheel from hard left to hard right is required but I want to know if anything else is required to calibraye or initialize the sensor.
