E36 M3 (1995-1999)
Im not really sure if my clutch is not disengageing or just wont engage. It was running fine then i parked it for a couple hours. when i went to leave and started it up, it wouldnt go into gear. I push in the clutch and it does nothing. Help please, i dont know to much about clutchs
If it was working fine and it just quit working you might have lost a clutch master or slave cylinder.
is there a way to check? wouldnt it lose all pressure in the pedal if i lost one of the cylinders?
I have replaced my master and slave twice, the clutch and the clutch pedal and I still get the problem with my clutch pedal not working intermitently. What did you do to fix your problem?
My original problem was just a bad clutch. When i pulled my old clutch off, the clutch disc was fused to the pressure plate. Then the clutch kit i bought was the wrong one, so when i put it in, there was to big of a gap and the slave couldnt reach the through out bearing all the way. after i got the right clutch in it, it all worked perfect.
