Programing power seat settings into my key fob - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 02-12-2005, 04:48 PM
jdeday's Avatar
jdeday jdeday is online now
Send a message via AIM to jdeday
Mein Auto: 2005 BMW X3 3.0
Hello everyone,
Today I took delivery of my new 05 X3 and I can't figure out how to program the power seat settings into my two key fobs. I did have this feature activated at my dealer, he had me walk through it at the dealership by inserting the key into the ignition, select #2 seat position and program my set settings into memory. But when I change the seat settings, lock the vehicle and unlock it with my now programmed key fob it doesn't return the seat settings.
What am I doing wrong?
Thanks.
Jeff
Old 02-12-2005, 07:19 PM
Quicksilver's Avatar
Quicksilver Quicksilver is offline
ggcbmwcca.org Member
Mein Auto: 2005 X5 4.4
Originally Posted by jdeday
Hello everyone,
Thanks.
Jeff
I believe you need two keys to accomplish what you wish. Key # 1 remembers what your programed settings are only after the vehicle is locked and someone else opens the vehicle with another key. If the second key is inserted into the ignition and a seat position is memorized and the vehicle is locked again Then when you access the vehicle with Key #1 it will remember the seat settings for that key. Open with key #2 and it will change the seat programed for Key#2. Thats the way it was explained to me.
And indeed I just went out to the garage and tested it myself and thats the way it works.
2005 X5 4.4 - Saphire Black on Black. light Poplar wood,
CD, Nav, Rear climate, Premium Sound. 1989 Mercedes 300E. Previous BMW, 1987 735i.
Old 02-13-2005, 09:39 AM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
Why does BMW have to get so complicated?
Dan
'03 325i OrBlu
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
Old 02-13-2005, 01:12 PM
jdeday's Avatar
Thanks! I just didn't complete the programing fof the key by locking the doors.
Old 02-13-2005, 05:31 PM
thunderX thunderX is offline
Mein Auto: X5
Here's how that system works and how to use it...
The memory seat buttons are separate from the Key Memory. The Key Memory returns to the last settings from when that key was last used when the doors were locked and unlocked. So to use both systems together, start car and do this:
1. Driver 1 gets in and sets all settings as desired, presses M on seat then memory button 1.
2. Test the setting by pushing memory 1 to see if anyting moves. If nothing moves, you're fine.
3. Lock all the doors and unlock. This sets the Key Memory to that setting, which is now the same as memory button 1.
4. Driver 2 gets in and does the same, but for memory button 2.
The Key Memory can be set at remote unlock, so when Driver 1 presses the unlock button on their key, the position saved above is activated. Same thing happens when Driver 2 presses the unlock button on their key.
The other Key Memory setting is at door open.
In total, you can have more than 3 settings- 3 from the seat memory and one for each key you have.
thunderX
Old 05-03-2011, 02:32 PM
GCamoriano GCamoriano is offline
Mein Auto: 2005 X5 3.0i
Question need help with program key to move seat to my preferences
I tried the procedure but it failed to program my key to my seat settings. I have my seat setting preference in memory 1 by adjusting the seat (and mirrors and steering wheel) to my preferences and then, with the key on the ignition, pressing the M button followed by the 1 button. I then tried your recommended procedure with the key so that, when I unlock the car with the key remote, the settings go to my preferences. I removed the key, locked and unlocked the car.
Then I took a second key (key 2) and I moved the seat settings to a new setting (call it memory 3), got out and locked the door. When I then unlocked the car with Key 1 remote, the seat did not move from the M3 settings!
Any recommendations from here?
Old 05-06-2011, 10:51 AM
RachaelsX5 RachaelsX5 is offline
Mein Auto: X5 4.4i
I just purchased a new key for my 01 and the rep programmed it to the car I asked if when it unlocks will the seat adjust to memory 1 and he told me 01 doesn't have that feature is that right?
Old 05-06-2011, 06:09 PM
tmvE39/E53/Z32's Avatar
Seat memory must be set by dealer http://www.xoutpost.com/articles/x5/...formation.html
Old 10-08-2012, 07:50 PM
dalehcoleman dalehcoleman is offline
Mein Auto: X5
I do not have my owner manual can someone help with set my auto set ajustment, it go all the way to the layback position when I unlock doors how do I ajustment them please?
Dale
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
Help! Key Memory & seats binaryfarms 3 Series & 4 Series 11 03-23-2003 01:32 PM
Key memory observation. cwa 3 Series & 4 Series 6 10-09-2002 03:06 PM
when to expect key fob programmed options sheet? punkman79 3 Series & 4 Series 9 04-01-2002 06:28 PM
