X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
#26
It's a very common problem. Sunroof is causing it due to blocked drain tubes Door is causing it due to damaged vapor barrier Rear window washer is causing it due to leaking tube to rear washer that runs from front to back. Good Luck I had a smart answer like this once and pulled out smart phone and showed him there on the spot that there was several thousand people complaining.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more Last edited by Evlengr; 07-30-2011 at 07:17 PM. |
#27
SA's hate the internet!
#28
I have this problem now that it rained. I took the floor mats out and shop vacuum the carpet. Next I shop vacuum the leaves from the sides under the hood and on top and underneath the pollen filter. The plastic cover has 3 twist off screw cover that pops up with 1/4 turn. Exposed then the pollen filter and I shop vacuum underneath and found a paper advertisement stuck on the air hole.
Thanks to this post and the pics that helped. Now my carpet is drying and hope this solves the problem next rainfall. |
#29
This problem is rather annoying. AK65. Thanks for your help. After an october nor'easter with alot rain in my parts I am dealing with this issue now. One really specific question. The black "windscreen", I understand how this functions, but after inspecting (mine X3 2004) it appears that this is not ""Snug"" to the windshield. There seems to be a small gap and in my mind that will allow water to sneak behind. In this instance if the "drain hole" is clean but the the "windscreen" is not snug is your opinion could this also be the cause for the water to run in?
signed - cleaning up a stinky mess this weekend! Thanks |
#30
AK65, sorry for this having happened to your X3! Also, though, thank you for this informative post and thread. I took a look at my '08 and, sure enough, lots of old leaf and seed debris in the area, including those two drain holes. Took it to the gas station and vacuumed it out. An easy maintenance procedure that quite obviously had NOT been performed, at least recently, by my dealer. I will show the service folks at the dealership what I did next time I have it in. I bet they are clueless, yet will appreciate the knowledge. Again, thanks for alerting all of us to this!
Flooding in Footwell
Same Problem. My car is always parked outside under a tree. Severe flooding in footwells, vapor barriers ok, definitley not the sunroof.
I'm not an engineer, but I appreciate I'm not alone with this problem. |
#32
After cleaning out the drains, slowly pour some water down into the holes to be sure there still isn't a blockage downstream, then replace the cabin air filter (use a clean one if your old one is dirty), and you should be good to go.
X3 w/6-speed & Sport Package: A sports sedan disguised as an SUV... |
#33
Flooded Footwell
Does this advice apply to the 530i?
Kudos to so many folks who know more about their BMW than trained mechanics.
#34
I'm not familiar enough with the 530i to say definitively; but it's quite possible, if the cabin air filter intake on that model is in the same general location as the one on the E83 X3. And it likely is, since this is the area from which most manufacturers draw air into the cabin from the exterior, whether or not a filter is involved in the process. Generally speaking, it's best to keep debris and snow/ice clear of that area on any vehicle so the HVAC can perform properly.
