Old 10-09-2012, 11:57 AM
Lost240 Lost240 is offline
Mein Auto: BMW X3 3.0i & 328xi
What do these warning lights mean?
Any ideas?
Sorry the pic is upside down.
Old 10-09-2012, 12:37 PM
jdauria jdauria is offline
Mein Auto: E39 ///M5
those look like the dreaded transfer case problem lights
http://www.bimmerfest.com/forums/sho...d.php?t=566880
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 10-09-2012, 12:55 PM
That is what I thought at first too, but the ABS light is not on. The auto transmission light is.
Old 10-09-2012, 12:56 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
Are they on permanently, or do they go away when car is turned off and later restarted?
If the latter, most likely nothing to be concerned about - electronic gremlin, possibly caused by low battery.
If the former, you need to look up: The terrible triad (TTT).
The TTT is usually the 4x4, BRAKE and ABS lights, I believe.
But your combination occurs too, I think. Some have reported all 4 lights on - might depend on year or the actual source of the problem.
When the A/T light is on, the transmission seems to operate in a protected mode, and makes the drive really odd.
Turning steering wheel lock to lock while idling might fix it if it was the steering angle sensor that needed re-initialising.
If transfer case fluid has never been replaced that should be the next thing to do.
Third, might be worth the $100 for a diagnostic as it could be any of a number of sensors that have failed.
If it is the transfer case itself, or its actuator, you should hear some audible clues.
Can't see your odometer unfortunately in the picture - but this can happen at any mileage and any year.
Old 10-09-2012, 01:00 PM
The car was shut on and off several times and the lights are still there. The mileage of the car is right around 59,000. When should the transfer case fluid be changed?
I have noticed a slight shudder lately under very slow acceleration when I take my foot off of the gas.
Old 10-09-2012, 01:10 PM
BMW say it is lifetime fluid - but that just means the lifetime of the transfer case.
The lifetime can be short if the fluid doesn't get changed. Chains get worn if lubricant properties get exhausted.
Varying opinions here for change interval. Anywhere from every 25K miles up.
2004 models should definitely have had their fluid changed before about 50K miles (I'd guess) as initial fill appeared to be Dexron III ATF before the special BMW Transfer Case Fluid became available.
Old 10-09-2012, 01:15 PM
do you think its fluid related or actuator related? I am just curious because I know my e83 has almost 60k on it and I want to make sure that this doesn't happen
Supersprint Headers
SuperSprint X-Pipe
Old 10-09-2012, 01:20 PM
I am dropping the car off this evening at my local shop. I will let you know what they find.
Old 10-09-2012, 03:11 PM
Ok. I just went outside to bring the car to the shop and now all of the lights are off and everything is running just fine. I am hoping this was just an electronic Gremlin....
Old 10-09-2012, 03:14 PM
Definitely have it checked out though by a reputable BMW Mechanic
Supersprint Headers
SuperSprint X-Pipe
Old 10-09-2012, 04:11 PM
From my experience, it takes a cold start, or at least an hour shut off, for you to see if it is a false alarm or the real thing.
My expectation would be that no codes will have been left, so you might want to hold off on the diagnostic hookup expense.
Your slight shudder on lifting off the gas could be checked out if you think it is something more than the usual effect.
Make sure your battery is fully charged and get the transfer case fluid done would be my recommendation.
Old 10-09-2012, 04:34 PM
That's exactly what I was thinking. I had a feeling that dropping it off for the codes to be checked wouldn't make a difference. I think I will get the transfer case fluid changed and have the battery checked.
Thank you all for the quick responses.
Old 10-12-2012, 07:21 AM
It turns out that you were right. My battery had a low charge and was replaced. No more dash lights!
They explained to me that if the battery is low, the car will begin sequentially shutting off modules in order to reduce the power draw on the battery so the car will still start. So in this case the DSC was off and a few other modules were off triggering the lights.
Thanks again for all the help!
Old 10-13-2012, 04:42 PM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
And you would think a low/bad battery would trigger the battery light.... Good way to make us running around in circles !
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 10-13-2012, 04:51 PM
x3brian x3brian is offline
Mein Auto: X3
That is probably the most logical explanation I have ever heard on why the random lights happen when the battery starts to go.
Old 10-14-2012, 09:03 AM
Aficionado
Funny, I thought the same thing at first, then I realized that is misleading, thus my previous post.
-Mario Andretti.
___________________
