E36 (1991 - 1999)
Old 10-09-2012, 07:00 PM
bimmer765's Avatar
bimmer765 bimmer765 is offline
Mein Auto: 325i
Vanos
What would be the best way about fixing my noisy vanos. Dr.vanos has replacement options for the whole vanos with their upgraded seals. Or I could do just besian seals. Have any of you guys just had a good indy do it for you?
Sent from my SCH-I500 using Bimmer App
Old 10-11-2012, 06:09 AM
Echo46 Echo46 is offline
Mein Auto: 2006ZCP M3and 1999 M3vert
I chose the beisan refresh and anti rattle kit and did it myself. Not very difficult. Although I think Dr. Vanos is a very good option, I have heard that their replacement vanos has the same seals as the original which would lead to the same issue down the road.
Old 10-12-2012, 12:25 AM
Kentetsu Kentetsu is offline
Mein Auto: '98 328i
I had a noisy vanos, but it went away after using lucas heavy duty oil stabilizer. Over a year now, still no noises or issues. Just a thought.
Old 10-12-2012, 06:15 AM
bimmer765's Avatar
Mein Auto: 325i
How many miles, and what engine do you have?
Old 10-13-2012, 12:39 AM
Mein Auto: '98 328i
'98 328i. Issue started at around 125k miles, I put up with it until about 135k when I added the Lucas. Now she's at 155k and still nice and quiet.
Old 10-13-2012, 06:45 AM
bimmer765's Avatar
Mein Auto: 325i
Ill try that, I would to do the vanos fix on my E36 because ill probably have to do it on my E46 sometime down the road.
Old 10-14-2012, 10:21 AM
john kaminski john kaminski is offline
Mein Auto: 1994 325i
Bimmer 765, let us know how the Lucas stabilizer worked for you. Maybe that stuff has the right things to restore the seals ? Would save a lot of work if so - probably would want to throw some in on higher mileage engines just a preventative if it works that well. I'm generally suspicious of these overhauls in a bottle but for seals a proper softening agent might just work. Anyone else tried this ?
Cheap Trick
Old 10-14-2012, 11:25 AM
bimmer765's Avatar
Mein Auto: 325i
Ill let you all know, since I have 183k miles.
Old 10-19-2012, 08:51 AM
Mein Auto: '98 328i
We use Lucas quite a bit in the Rotary engines. I don't think it's so much about "restoring" or "swelling" the seals. I think it has more to do with its tendency to "crawl" up to areas that usually don't get very good lubrication.
Old 10-19-2012, 11:24 AM
bimmer765's Avatar
Mein Auto: 325i
Well when I get my replacement radiator back on ill drain a couple quarts of oil out and pour this in. I picked up the synthetic type of lucas so we'll see how it goes.
Old 10-24-2012, 10:37 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
IF you are doing the vanos...
Go besian.
Dr Vanos.. not so much.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 10-29-2012, 05:31 PM
bimmer765's Avatar
Mein Auto: 325i
Whats wrong with the Dr?
Old 10-29-2012, 05:53 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Nothing other than it uses the same seals as factory, which will just go bad eventually like the originals did.
1998 BMW 328is
1966 Pontiac GTO
Old 10-29-2012, 06:31 PM
bimmer765's Avatar
Mein Auto: 325i
Yea thanks.
Old 11-21-2012, 04:57 PM
bimmer765's Avatar
Mein Auto: 325i
Decided to change my vanos seals and no I have a problem. With mine being an automatic there is no room to get my hand up to the hole where the locking pin goes in. I have it at TDC and I'm ready to put the cam locks on. Would I be ok this way and make sure Im still at TDC before I put it back together.
Old 11-21-2012, 05:24 PM
hornhospital's Avatar
D'oh, You Kids!
The hole for the lock pin is in the FRONT, through the engine flange that connects to the transmission bellhousing. It's just below the starter.
Quotes to live by:
Old 11-21-2012, 05:36 PM
bimmer765's Avatar
Mein Auto: 325i
I can see it from above, but with transmission color lines in the way its almost impossible to get to.
Old 11-21-2012, 05:41 PM
D'oh, You Kids!
You really need the pin in place. I would never trust the engine to stay exactly at TDC while working on something as critical as the cams/VANOS. Figure out a way to snake that pin in there.
Quotes to live by:
Old 11-22-2012, 03:24 PM
bimmer765's Avatar
Mein Auto: 325i
Well I was able to get it done without putting the locking pin in. Put it all back together and its way more quieter than it used to be. I still hear a little chain slop but that would be taken care of if I did the diaphragm spring. Still happy with the results.
Old 01-23-2013, 05:11 PM
bimmer765's Avatar
Mein Auto: 325i
Well its been about two months since I did besian kit and now the noise is starting to come back. I even put in a quart of the lucas oil treatment and it still makes a lot of noise. This happen to anyone?
Sent from my SCH-R760 using Bimmer App
