Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 10-08-2012, 08:54 AM
samualcc samualcc is offline
I probably dislike you...
Mein Auto: 2013 328i Sport
Winter Tire Size for 2013 3 Series
Well today's 40 degree temperature in the Philly area today means the slow decline into freezing winter temperatures has started. I am familiar with the awesomeness that is winter tires having put them on by G35 Coupe and Honda Civic Si.
The question is on tire sizing. I have already decided to go with a 17 inch rim (I have the sport line, so 18s are standard on the car). Probably the A7 sport rim from tire rack. However I am curious if there is a practical reason not to choose the 215/55 R17 option over the 225/50 R17 size. I understand the loss in tire width, but I am not putting these on for super dry weather handling. There are far more options available at the 215 tire width, including some really good ones not available in the 225 width.
Any reason I should not consider this option?
2013 BMW 328i Sport - Back in the family!
2007 Honda Civic Si Sedan (Retired, Meh)
2005 Infiniti G35 Coupe 6MT (Retired, great car)
2002 325xi (Retired, very much missed)
Old 10-09-2012, 11:04 AM
LMC's Avatar
LMC LMC is offline
Mein Auto: M3 & X3
Given that you understand and accept the tradeoffs with your "minus zero" fitment; I think you should be fine.
Larry
BMW CCA #115780
'14 X3 35i M sport
'17 M3
Old 10-10-2012, 05:30 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
215/55R17 is indeed the more common size. The only other downside is that there are no run flat winter tires in that size so you'll need to use non run flat snow tires.
Winter http://www.tirerack.com/a.jsp?a=AB2&...nter/index.jsp
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
