E28 (1982 - 1988)
Old 09-27-2012, 01:54 AM
thexpbogger thexpbogger is offline
Mein Auto: e28 1987 535i M Spec
A Quick Enquiry
OK......
I have just noticed the oil pressure light come on in my 87 535i...... I checked the dip stick and the oil is a touch below the 2nd marker........ exactly what is the 2nd marker supposed to be??????? i would check in my brand new BENTLEYS, but have to wait until I receive it from the UK...... Apparently AMAZON.COM will not post to me in AUSTRALIA (scumbags) so I had to purchase from the UK instead (thanks).............. gotta wait 4-6 weeks though!!!!!
I'm guessing if oil is correct, then it must be a dodgy oil pressure switch........ another problem to add to the GLITCH LIST
Stephen
Old 09-27-2012, 12:03 PM
legionnaire1857 legionnaire1857 is offline
Mein Auto: 2000 540i sport
The oil level is supposed to be between the two marks, the mark closest to the end being the lower side of the range. Oil pressure switch is a common failure.
Sent from my DROID RAZR using Bimmer App
Old 09-27-2012, 12:42 PM
catso's Avatar
catso catso is offline
catso
My oil pressure switch failed by leaking at the point where the wire connector enters it; very unusual. It's an easy and cheap repair though, they cost less than $20. You may want to actually remove the switch and check the oil pressure at that port with a good quality gauge, it will give you piece of mind.
Don't be gormless; get some gorm!
![/I][/FONT]
Old 09-28-2012, 03:42 AM
Thanks to the both answers............. noticed today the light actually went out for about 5 minutes but came back on again................... as for the oil level answer............ glad I am just on full and not dry...... can ignore the light for the next week or so until I hopefully get the BENTLEYS from the UK and a replacement oil pressure switch........
might as well do an OIL and FILTER change at the same time as the switch fix!!!!!!
Stephen
Old 10-07-2012, 06:53 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
Source a handbook too!
Current:
Previous:
Old 10-08-2012, 12:45 PM
Piston_broke's Avatar
Piston_broke Piston_broke is offline
What was that noise??
Mein Auto: E28 M535i, E30 323i
Stephen,
What state are you in??
and I don't mean are you drunk or sober!!
Old 10-10-2012, 06:02 AM
To.... Piston_broke
What state are you in??............. approximately 2000 Ks south of you in VICTORIA....
and I don't mean are you drunk or sober!!..... that's funny and I am straight when I wanna be S#$T FACED......
Stephen
HTML code is Off
