Old 10-10-2012, 05:51 PM
GabesJH82 GabesJH82 is offline
Mein Auto: 2002 BMW 530i
Slight vibration issue help! :(
Ok here it is 2002 e39 530i after I recently replace my stock muffler with an after market one magnaflow part # 14816 I had a good tone to it. On idle after I rev up the engine to like 3k rpm to be able to hear the exhaust sound, this was my first attemp, than i notice my car had a slight vibration issue only in the drive possition while holding down the brake pedal which that was the spot i was able to feel the most, it wasnt doing it before only after i rev up the engine, in park position theres no vibration issue. Not sure what it could be anyone experience this before pls help
Old 10-10-2012, 08:35 PM
Phuthuy85 Phuthuy85 is offline
Mein Auto: 525i
Check your front brake or upper control arms.
Old 10-10-2012, 09:05 PM
Vibration accures while at a complete stop waiting for the green light seems like my car is a little shaking. What can be the common causes for the car to be shaking all of a sudden?
Old 10-11-2012, 06:02 AM
Mein Auto: 525i
I dont know what's cause hat issue, but i'll check the spark plugs, and clean the air system, and wait for another experts to tell you to do next. Good luck
Old 10-11-2012, 06:33 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
I think you're being nick picking here. Your unique test condition doesn't occur under normal driving at all. If you hop in any car with 100K miles, put in drive rev to 3K and hold on to brake pedal you will feel a vibration is guarantee.
Another word vibration is expected when you put 225 foot pound of torque into an engine with old engine and tranny mounts, the vibration will then transfer onto the suspension but the suspension can't dissipate the vibration because you are holding on to the brakes.
Now, if you have a vibration at 3K RPM while driving then it's another story.
Old 10-11-2012, 08:11 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
I would check the exhaust. It might be an issue with the placement of your muffler. When you put it in gear and the engine flexes your motor mounts the exhaust might be touching something causeing a vibration.
Old 10-11-2012, 11:21 AM
gchand's Avatar
gchand gchand is offline
Mein Auto: 03 530i sport
John has offered another on point recommendation - OP has done this load "test" before and after the only apparent change made to the car (new exhaust), something I never heard of or would do myself with an auto tranny, but ce la vie.
