Old 08-15-2012, 08:30 AM
David fierro David fierro is offline
Mein Auto: BMW 745i
PLEASE HELP 2002 745i
Can someone help me my car won't start 2002 BMW 745I the codes that pulled up are 2862
and 2863 Variable valve gear voltage supply,power output stage bank one and bank 2
It cranks over but jus won't start!!!
Old 08-15-2012, 12:54 PM
SFbay SFbay is offline
Mein Auto: BMW 745i
Check vanos solenoids plugs and voltages
Old 08-15-2012, 01:02 PM
Mein Auto: BMW 745i
Hey thanks I will check voltages and all connections to tha vanos
And get back to you ok!
Old 08-15-2012, 02:59 PM
bayerisheteknik bayerisheteknik is offline
Mein Auto: e65
did you get the 7 running?
Old 08-16-2012, 01:30 PM
Mein Auto: BMW 745i
No luck yet still cranking ova with no start! Im going to check my vanos solenoids
I replaced one not to long ago that was leaking oil. I think it's kinda weird cause it's calling for bank 1 and bank 2. Would one vanos solenoid cause my car not to start and call for bank 1 and
2?
Old 08-16-2012, 01:50 PM
Mein Auto: e65
2?
maybe camshaft/crankshaft sensors....check fuel pressure
Old 08-16-2012, 06:05 PM
Mein Auto: BMW 745i
Checked for fuel pressure and it has none and yea it has 1/2 a tank?
Old 08-17-2012, 02:39 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
Think your misunderstanding the error.
The error codes are relating to the voltage supply to both variable valve actuators.
Sounds like you have a supply out, have you checked fuses in the engine control unit box? Supplies to the VVT module etc???
Stuart
Old 08-17-2012, 02:44 PM
Mein Auto: e65
you have found your problem...it can be fuel filter...fuel pump...fuel pump relay..fuse..regulator maybe you tripper the safety switch for fuel cut off somehow...
Old 08-22-2012, 08:00 PM
Mein Auto: e65
did you ever figure out the cause of your 7 not starting???
Old 09-05-2012, 10:04 AM
Mein Auto: BMW 745i
Just installed a new crankshaft sensor but it did not start I guess I'm having no luck!!!
Old 09-05-2012, 10:50 AM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
I'm a noob to the forums but I just got done reading another topic and wonder if they are similar. Here's the link...
http://www.bimmerfest.com/forums/sho...d.php?t=557752
Old 09-05-2012, 11:54 AM
Mein Auto: BMW 745i
No it's not the same thread k!
Old 09-05-2012, 06:13 PM
johndade johndade is online now
Mein Auto: 2002 bmw 745li
I just had a crank no start issue would happen once a week for month or so then finally wouldnt start even after the other times i let it sit for awhile. Ended up being the satellite b pillar module it was shutting off fuel pump and wouldnt let it start. Dealer thought it was battery first but then it did it couple weeks after battery replacement. Just got the car back today so ill give it couple weeks see if anything happens they better hope they have the fix right this time.
Sent from my Motorola Electrify using Bimmer App
Old 09-05-2012, 07:20 PM
chrisrees chrisrees is offline
Mein Auto: 02 745li
Crank shaft position censor
Repairs 2012
wishbone & steering rack
Rfmd hydro steering gea
combination nu
Ball Joint
Tension strut with hydr
Switch unit steering column
Coils 5&7 and new spark plugs
Faulty DSC Control Module
Fuel Gauge
Leaking Crank Case Vent Valves
Power Steering pump, washer pump and grommont,
Crank Shaft position sensor
Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
Old 09-05-2012, 09:16 PM
Mein Auto: BMW 745i
Sorry to hear that I know there expensive to keep running but they sure do drive nice
I do most of the work my self so yea I can see it getting expensive if u take it a BMW dealer
My has being down for a while and getting desperate lucky I have a Audi A4 quattro I can drive mean while!
Old 10-10-2012, 09:37 PM
rey745li rey745li is offline
Mein Auto: 745li
i have a 2003 745li , I had a crank no start issue for a couple of months and now my car hasn't started in a week with many tries, a few weeks ago my friend who is a car mechanic looked at it he said the fuel pump was getting power but it still didn't start but it started the next day, i haven't been able to get of my friend and my car has been stuck in my job's parking lot for over a week, two questions, is there a way to check for sure if its the fuel pump and if its not that is it hard to change the satellite b pillar module,
thank you
Old 10-11-2012, 07:45 AM
Mein Auto: BMW 745i
My car is not running yet waiting for my Super scanner to come in but yea I know there is a relief valve up in the engine compartment u can press on that while u crank these will assure ur getting fuel pressure k. As far as the pillar module not sure I would recommend you order these scanner that I'm waiting for it's suppose too start my car it's not expensive only like a $120 super scanner et801 BMW code scanner on eBay it's far away so be prepared to wait a week or soo. I'm hoping mine comes in today or tomorrow so I will let u know if it stars mine!!
Old 10-11-2012, 10:31 AM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
that scanner looks pretty cool...
cant wait to hear your thoughts on it.
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato
BMWE65: 20x10 / 20x11 Asanti ELT
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS400:Air suspension,MAJOR A/V setup, 19"Leon Hardiritt
Lexus LS430: VIP , custom Air Suspension, 19" Amistad (SOLD 2012)
