Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 10-11-2012, 04:20 AM
GreekboyD GreekboyD is online now
Mein Auto: 2009 BMW 335d
Is it possible to swap Quaife LSD from 335i to 335d?
I know the open differential is welded on for our 335d vehicles. Is it possible to take an existing Quaife LSD on a 335i and put it on our 335d or are both LSD units for either model built differently?
Thanks.
Old 10-11-2012, 04:38 AM
Axel61's Avatar
Axel61 Axel61 is online now
Mein Auto: 335d
Call Lenney as I infoed you in the other site, and good luck
RENNtech Flash, WAGNER IC,Koni FSDs,Execuhitch,VMR710 19"
Old 10-11-2012, 08:22 AM
62Lincoln's Avatar
62Lincoln 62Lincoln is offline
Mein Auto: 335d
GBD, I think you'll need to address the difference in final drive ratios. From the factory, the 335i is 3.462, and our d is 2.813. I don't know if Quaife varies final drives or not, but that would be the central issue, as I would assume the fitment would be the same. Can you contact Quaife directly?
Old 10-11-2012, 04:05 PM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
I know one user put an aftermarket diff. into his to get the same end result I think you are looking for. Are you though talking of just swapping the diffs or much more than that? If just diffs then wouldn't that mean swapping the ring and pinion?
--Aaron
Old 10-27-2012, 06:31 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
The issue is with the different gear ratios between the 335i vs. 335d. Since the ring gear is welded on the 335d, there are two options - 1.) swap for a bolted 335i differential, or 2.) find a machine shop that can weld a new 2.81 ring gear to the quaiffe differential. If the 335i differential is swapped, fuel economy will suffer and you might have driveability issues. The best solution would be finding a shop that can weld the ring gear.
Old 10-29-2012, 04:48 AM
Axel61's Avatar
Mein Auto: 335d
thats an expensive swap wont a QUAIFE be a better solution
HTML code is Off
