First major break down: Overheating
Hey fella's, I had my first major break down last night coming back from dropping a friend off at the train station. I was on the highway and I happened to look down and see that my temp guage was in the red at about the 1:30 position. The red section of the light was on but the needle wasnt quite pegged. I felt helpless because I was in a construction zone and could not pull over immediately. As soon as I saw that it was overheating I did what I could and drive very gingerly and within about 10-15 seconds of me noticing the light being on the guage dropped right back down to normal and at that time I was then able to pull over. No smoke from under the hood and all the radiator hoses were still in place and flexible. The coolant was okay. So I decided to start her up again and see what happens. I started driving and within maybe a 1/4 mile the temp guage started to rise again so I pulled over as soon as I saw that. This time I only let it get to maybe at most the 1230 position before I pulled over. Had it towed back to school and will most likely have it fixed at a german car repair shop called Autobahn in Albany, NY. Does anyone have an past records with them by any chance? But mainly, any ideas as to what could have caused this overheating?
Thanks guys I really appreciate it!!
1997 BMW 528ia l Bilstein sport struts l H&R springs l smoked LED tail lights l smoked headlight lenses l smoked side markers l M5 trunk spoiler l 17" TRM rims l *custom IPod ashtray dock* l black chrome kiney grille |
You have 573 posts and have not heard about cooling overhaul?
http://www.bimmerboard.com/forums/posts/199986 |
Needs more coolant & be sure to bleed it. I think best is to just come to 12 on morning warm up, then open & fill. Coolant then won't boil over during fill. I fill to near the top of tank in such case. Squeeze the return hose, should feel coolant filled up in there. If problem persists on highway, likely coolant leak.
In your case, likely bad thermostat (stuck closed) or broken water impeller.
The problem with cooling system is: once a part breaks, the other parts follow like clockwork. So replacing things bits and pieces is a bad idea. Once the engine overheats, you are now talking about $3000/$4000 repair bill. So spending $500 now for cooling overhaul is a wise investment. You other option is to wait until other parts fail, then it is $500 for cooling parts + $3000/$4000. The math is very simple $500 vs $4500. |
Oh I gotcha now. I didn't think of each part failing right behind the other. I was looking around and Ive done a lot of business with turner motorsport and they have a complete overhaul kit.
Mfg of the parts matter! For The best bang for the buck:
- WP: Hepu $65 - Hoses: BMW - Rad: Nissens - Fan Clutch: Sachs - Fan Blade: BMW - Reservoir: BMW only, and even so it will crack after 5 years, trust me on this. - Tstat: Wahler only - Tstat housing: BMW Plastic. Re Aluminum, search for the pros and cons. - Belts x2: Contitech - Rollers x3: INA or BMW - Tensioners: INA, SKF or BMW |
http://www.turnermotorsport.com/p-14...-e39-528i.aspx this wouldn't be sufficient?
That kit looks good but you could probably piece it together for cheaper. You will also need an expansion tank and ask them if the one they offer is genuine BMW. You could also save money on a Graf WP with the metal impller.
Sorry for the offtopic but I noticed this wrench is going for $55 and I just had to laugh. Guess it was made by Sasquatch himself coated in God's saliva.
No.
Shop for the items I mentioned above separately. Some useful links: http://www.bmwmercedesparts.com/part...?siteid=215771 autohausaz.com eeuroparts.com |
don't forget furiousmethod.com to compare prices.
That looks like a Stahlwille wrench which are expensive but the best you can buy. For any of us Harbor Freight would be a better value though, even though working on BMWs is more fun and easier with quality German tools like Stahlwille or Hazet.
"Formula 1 is better than NASCAR... If you compare them to musical instruments F1 is a Stradivarius violin, NASCAR is banging a saucepan with a wooden spoon." -Jeremy Clarkson |
More than you ever wanted to know about tools for a cooling system overhaul (1)
