Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 08-08-2012, 09:41 AM
unvecchiomac unvecchiomac is offline
Mein Auto: 325I
01 740i - multiplicative catalyst limit reached?
2001 740I, 142000 miles on the speedo. check engine light came on, scanned codes and found "multiplicative catalyst mixture adaptation control limit reached" plus MPG was down so replaced front sensors. car ran great and smoother but now a week later check engine light is back on with same codes. looked at the data stream and all sensors are responding as good sensors with voltage sweeping from .2 to .9 volts. any ideas?
Old 10-12-2012, 12:57 PM
Maddogg Maddogg is offline
Mein Auto: 2001 740IL
Yeah, say that 5 times fast.....
Old 10-12-2012, 09:25 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
Maybe car speak for 'cats gone bad'?
Current:
Previous:
Old 10-13-2012, 07:28 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Have you scanned the car using INPA? If yes, could you post the freeze screen's, I would like to compare with mine. Is this the only code? What is the 4 digit format? You might have a vacuum leak, and the DME cannot compensate anymore with gas, in order to have a good mixture for the cat converters. For instance I am fighting a vacuum leak and I have a code for the vacuum leak and also INPA is giving me the mult. catalyst reached.
JOY = BMW
HTML code is Off
