Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 09-16-2012, 10:39 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Links to said sources, please. Only alternators with permanent magnets (in other words,not those used in automobiles) can self-excite. On all others, no matter how fast they are spun, they will not spontaneously start creating electrical energy.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 09-16-2012, 05:09 PM
downhiller's Avatar
livin large
Downhiller, I agree with you 99% of the time, but on this you are dead wrong. You can spin an alternator as fast as you want, but until there's excitation voltage it will generate nothing. An alternator has no magnetic field without excitation voltage. No magnetic field= no electrical generation. Generators had permanent magnets and didn't need electrical current to start producing electricity, but alternators absolutely MUST have a magnetic field created by electricity in the windings before they'll do anything at all.
so youre saying the magnetic rotor that is built with a magnetic material isnt magnetic until it is powered? did you know there isnt anything wire wise on the shaft to the rotor? and if this is true from what you are saying, then there will be a dead short within the electrical system because the rotor would in theory be grounded.
not trying to be an ass here, but when the guys at youre trusted autozone, napa, etc just hook the alternator up to a belt and use a starter with a couple leads to a volt meter. really want to see something awesome, that proves me right. take the wires off the back of the alternator. leave everything else attached. start the engine with a volt meter across the leads on the alternator. youll see about 14 volt (depending on how strong the windings are).
Old 09-16-2012, 06:58 PM
D'oh, You kids!
Click the link that johnf posted and see what that says about the rotor of an alternator. It is NOT a magnet until it is energized by, guess what, the excitation voltage through it. And the test you got at Advance? Guess what the two wires to the alternator did before they started pulling current out of the spinning alternator? Yup...sent excitation voltage into it. Of course you'll get 14ish volts off a running alternator if you pull the wires. You already had it started with excitation voltage before you pulled the wires. An alternator's excitation voltage is self-sustaining once it's producing current.
I'm not trying to be an ass either, but I know alternators and electrical systems. I've been working on them for forty years.
Sent from my MB860 using Bimmer App
Quotes to live by:
BMW-CCA #441426
Old 09-16-2012, 11:01 PM
goat88 goat88 is offline
Mein Auto: 1989 BMW 325I
Well if you read the whole article on wikipedia regarding automotive alternators its says plain as day that they can self excite, the other "various sources" i used was to confirm that it was a true fact
Old 09-16-2012, 11:06 PM
Anyways I figured out my idle problem it turns out that when I was removing the air box I pushed a radiator hose into a cluster of wires and 1 of them came undone (poorly reattached harness) so a little electrical tape and wire strippers fixed that problem, but once again my battery is draining out the alternator is brand new and its still not keeping a charge to the battery so I'm back to checking wires again :/
Old 09-16-2012, 11:15 PM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Send a message via Skype™ to BmwMan92
Mein Auto: 1985 318i// 1988 325e
I'm having this problem now =( something is draining my battery.. I'll figure it out tomorrow
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 09-16-2012, 11:49 PM
woenvlgo woenvlgo is offline
Mein Auto: 2008 BMW 520
agree. i'm without words.
Old 09-17-2012, 03:47 PM
downhiller's Avatar
livin large
but it also mentions alternators that self excite after a certain speed, so if they can self excite, that means there has to be a magnetic field to start with, correct?
Old 09-18-2012, 01:20 AM
Well i finally got my car back on the road again, i ended up replacing a worn alternator, a bad battery(it was also the wrong kind) the negative cable from the battery to the trunk, and the positive cable from the alternator to the starter
Old 09-19-2012, 12:43 AM
Nick323's Avatar
Nick323 Nick323 is online now
Nick's Toys
Mein Auto: 323i E30 2-door
Unhappy Battery placement
Why do some manufacturers put the battery in the trunk
Weight distribution ! C'mon is it that critical to distribute that little bit of weight to the back on a road car ?
The thick cables leading to and from the engine bay weigh nothing ? & then the losses...
& then some smart ass copies this layout, gets it all wrong and wonders why his engine now performs ****ty
The elctronics guy inside me scratches his head in bewilderment
Don't take life too seriously; no one gets out alive !
Old 09-19-2012, 03:54 PM
downhiller's Avatar
livin large
yes it is important. dont anger the gods.
on a side note, mercedes, vw, dodge, honda (hybrids), toyota (hybrids) either put them in the trunk or just behind the rear seat. go change a battery on a dodge magnum then come back and tell us the lovely time youve had with it
Old 09-20-2012, 02:14 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
It does help balance the load, keeps the battery away from engine heat and fumes and makes space in the engine bay. The thick cables going to the back are not so heavy.
Lots of cars have the battery under the rear seat or in the boot...trunk if you are in the USA
The only problem I have with this is that a charging battery, escpecially if it is an old un-sealed lead acid battery, can give off hydrogen fumes which could go "Boom" if your back seat passenger lights up a smoke.
Oh and as regards the issue of can you push start an E30 without a battery fitted....why does somebody not do a test for us and put us out of our missery??
I personally believe that the metal core of the rotor will pick up some magnetism over time and will become a "weak" permanent magnet and hence self-exitation can happen if you spin the alternator fast enough!
Old 09-20-2012, 10:54 PM
Gotta admit though it makes wiring up a pair of 12in subs with a 1500 watt amp a little easier
Old 09-25-2012, 11:07 AM
Bandem Bandem is offline
Mein Auto: BMW
Alternators used in automobiles are not self exciting. You CANNOT start a vehicle with an alternator without a excitation. hornhospital is 100% correct. In fact, i'm not sure, but I believe on many BMW's they have a minimum voltage requirement set to start, otherwise it won't even let you try.
I'd like to see a video of a car with an alternator and manual transmission being push started without a battery or some power source.
Old 09-26-2012, 01:17 AM
Nick323's Avatar
Nick's Toys
Thumbs down How to ruin an ECU
Sheesh, why not do an empirical test & blow up the ECU
I am not concerned about theory and how incorrect Wikepedia is this time (its dodo's like me who write junk on there)
What I worry about is how it translates to practice !
& practice is not to ever run your Alternator without a buffer (Battery) connected to it
Your Alternator generates some interesting Voltages before it goes through the Bridge & then regulator.
I used to take the Voltage after the bridge & use the Alternator as a welding machine
So if you run it without a Battery to smooth things out, it could cause some interesting smoke
Old 09-26-2012, 01:41 AM
johnf's Avatar
johnf johnf is online now
John Firestone
Mein Auto: 1996 318is
In case you are curious, BMW's requires components at the generator output withstand +/-8V of ripple at 14.8V (a sinusoidal voltage swinging between 6.8 and 22.8V).
What you really don't want to happen is have the battery disconnect with the generator at full power. I don't think the E36 has a central suppressor to quench the resulting load dump.
Old 10-13-2012, 11:55 AM
BMWEnthus BMWEnthus is offline
Banned
Mein Auto: 89 325i
Not sure if you figured out your problem yet but mine did the same exact thing come to find out a fuse had blown! Not sure why that killed it but after a little thought i figured out that the negative cable on my battery corroded completely through from the battery end to the bolt on the car it made it drain but would impede charging! I bought a 6 dollar replacement cable from walmart of coated copper and like magic! Never had a problem since!
This captain goes down with the ship
