Old 09-11-2012, 09:42 AM
Originally Posted by tmvE39/E53/Z32 View Post
NO oil can save your BMW engine from failing cooling system.
+1.
Just ask these people who lost their engines (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Old 10-12-2012, 09:32 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
Originally Posted by edjack View Post
Methinks that far too many people are obsessing over oil, and what to use. The single most important issue is changing it in a timely manner. Most people in the US of A operate their cars in what can be termed "severe service;" i.e., short trips at rather low surface street speeds. This requires more frequent oil changes than the idiot Service Interval Indicator tells you.
I've always been a 3k oil and filter change kind of guy, using dino oil. I would rate my pattern of usage as severe service. My engine is squeaky clean, with no tan varnish deposits anywhere - the aluminum sparkles.
This whole oil discussion smacks of "chrome-plating a dog turd."
Ed, there is nothing wrong with changing Motor Oil sooner then the factory recommended service interval other then the cost, since used motor oil is now recycled, it's also no longer a environmental issue with disposal, but your motor will last considerably longer using a full synthetic motor oil then by using a standard petroleum based motor oil. When I sold motor oil at Supershops in Santa Clara and the Speed Merchant on Lincoln in San Jose in the 1980's, a case of Valvoline Motor Oil (12 quarts) on sale was 9.99. Mobile One synthetic's cost back then was nearly 8 times more per quart, not so today.
Here's a million mile BMW:
http://www.mobiloil.com/USA-English/..._in_a_BMW.aspx
Old 10-13-2012, 12:01 PM
jp5touring jp5touring is offline
Mein Auto: 525i touring
I can get seven quarts of Mobil 1 0w-40 for like $ 45.00 A Mann filter online for under $ 5.00 I change it myself,,, Heck I enjoy changing it, I change it every five thousand miles or so.
Its Cheap relatively speaking. Overkill ? most likely. Why chance something that could cost so much to repair for so little savings in the long run ???
If people want to go 10k or even 15k between oil changes have at it. Oh when you go to sell your car make sure you state in used car ad
You changed the oil every 15k !! good luck with that..
Old 11-24-2012, 10:53 AM
Sonare Sonare is offline
Mein Auto: 2000 E39 touring
My E39 with 220k gets Syntec and a filter every 10k-- at the suggestion of my mechanic. He sees a few more cars than any of us, and when questioned he replied that his observations led to and justified his recommendation. And in a way, he sells oil- at retail. Lost profit!
Rich
Rich
2000 528it (5-sp manual, M52TU engine, 220k miles and going strong) Bimmer #13!
