Old 10-13-2012, 01:45 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
Rear headrest removal tip
Ok guys, after trying to figure out how to remove them, the YouTube videos all were saying to remove the seats and this that and the other. I found a much quicker, cleaner way to get them out.
1- open trunk
2- Lay in trunk looking up
3- You will see the two headrest post bottoms for each headrest (except the middle).
4- Use a carpenter hammer and a 1/4" ratchet extention to tap them upward. (Be careful, don't drop the hammer on your face). Mine only took about two light taps per post. Came right out.
When I tried to pull them up from inside, nada. Good luck with that method. I cracked one of the speaker grilles doing this method. Figured I'd post this so I'd save some people the aggrivation.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 01-22-2013, 01:04 PM
SamS's Avatar
SamS SamS is offline
Mein Auto: 2013 ActiveHybrid 3
Hi,
Came across this post since I am stumped on removing my headrests. I need to remove them to accommodate car seats. For a front-facing full-size seat, you have to extend the rear headrest to the maximum height to clear the seat. At the max height, this creates quite a visible blockage out the rear window.
I would like to try this method described above. Should I extend the head rests to their max height before trying to tap them out from the trunk?
SamS's Avatar
Hi,
Old 01-22-2013, 01:15 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Lift them to full height, slide a hand under them, and yank up. A good tug or whack and they pop right up. I've taken them off numerous E38 & E39 like that. No special tricks at all.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-22-2013, 01:21 PM
SamS's Avatar
I already tried that... have you tried on an F30?
Old 01-22-2013, 01:41 PM
King of the Ballers
This is the E39 section, if you're dealing with an F30 you need to ask there, the instructions may be the same or may be wildly different.
When you search the forums, use the box on the right of the search page to limit your search only to applicable subforums or the results you get will not be useful to you.
You're a derbanana
Old 01-22-2013, 01:53 PM
SamS's Avatar
Oops sorry. I am usually good at the subforums, but came across this one via a google search. I'll give it a shot in the F30 section.
