Old 10-13-2012, 12:29 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Coolant leak: lower hose needs change.
The other day I got the message of low coolant. This morning when I went to wash my car same message appeared again. I knew something was wrong. Upon inspection I noticed the leak coming from the plastic piece on the low side of the radiator. Called BMW and that part is one piece of the lower hose. How easy is this piece to replace? Any help/tips much appreciated.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-13-2012, 12:40 PM
pmpn8ez's Avatar
How much coolant to replace if drained?
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-13-2012, 02:31 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Just either by the washer that goes on the temperature sensor or buy a new temp sensor with the washer. I think that is leaking instead of the hose.
Old 10-13-2012, 05:30 PM
pmpn8ez's Avatar
You are exactly right. Went to buy the hose and the parts salesperson recommended same part instead if the hose. The rubber washer is known to wear and cause to leak coolant. Unfortunately they do not sell just rubber washer. I bought the sensor with new washer. $45. Pix of the old temperature sensor.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-13-2012, 05:43 PM
pmpn8ez's Avatar
Seems like other models are having the same problem. Here's a thread from 6 series forums with a cheap fix from Home Depot O-Ring $3.
http://www.bimmerfest.com/forums/sho....php?p=6422410
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-13-2012, 08:50 PM
wjjklj's Avatar
They do sell the part. Part number is 13621743299. It costs $0.71 from thebmwpsrtstore.com. The sensor is part number 13621433077 and costs $19.08 from the same place.
Old 10-13-2012, 09:39 PM
pmpn8ez's Avatar
My stealership only carried the sensor and not the O-Ring.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-14-2012, 08:39 AM
wjjklj's Avatar
Glad you got it fixed. Still better than replacing the hose.
Old 11-09-2012, 02:53 PM
FLEXAMILLION FLEXAMILLION is offline
Account Under Review
Mein Auto: 2003 745LI
mine is doing the exact same thing.... Im fixing it this weekend....
Old 11-09-2012, 03:08 PM
1bad540's Avatar
1bad540 1bad540 is online now
Mein Auto: E65 750i Sport,C5 z51 e46
I got snagged by the dealer on this , new hose, new sensor, ran around 600. didnt realise at the time it wasnt covered under cpo.
[SIGPIC]
e39 540i sport, acs type 2's,acs sper pdls,Euroclrs(sold)
e65 745i aw sport,21's aib's acspdls& rf splr(sold)
e46 328i Prem Aw18" 335spt whls(sold)
c5 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pana rf,nav,xenon,cldweather,20"4.6rims.(sold)
e65 750I aw, sport. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20"rennen forged,tune,exh,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
Old 11-09-2012, 03:12 PM
Sorry to hear that.... this Job, ill do myself... It's pretty easy...
Old 11-09-2012, 04:14 PM
pmpn8ez's Avatar
You can buy the rubber seal at Home Depot. $2 for a pack of 10. There's a thread with details in the 6 series forum. They have the same issue with exact same part.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 11-09-2012, 04:17 PM
pmpn8ez's Avatar
Here's the link:
http://www.bimmerfest.com/forums/sho...d.php?t=578644
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
