Old 10-12-2012, 05:26 PM
bimmer balls bimmer balls is offline
Mein Auto: 2001 bmw 325ci
Exclamation possible throw out bearing? HELP?!?!:(
i have a noise that sounds like rocks in a tin can that is present at idle and slow speeds, very loud and annoying, it only goes away when i hold in the clutch it gets louder when i drive and then stop someone help me please
Old 10-12-2012, 05:42 PM
jump to around 45 seconds and you can hear it go away when i press the clutch
Old 10-12-2012, 07:29 PM
elhombre's Avatar
elhombre elhombre is offline
Mein Auto: 2003 325i, '99 e36 328is
I'd rule out the throw out bearing. It does its thing when your foots on the clutch pedal. The noise occurs with your foot off the pedal (clutch engaged). I'd get the car off the ground (all 4 wheels), pull the splash shield and reinforcement plate then get under it and listen while somebody runs it and works the clutch.. Hope it's something simple, but from what I hear it does sound like a tranny issue- good luck.
Ps. Could be a dual mass flywheel or clutch (pressure plate or disc) issue as well.. Maybe the drive shaft guibo is giving it up- it really needs a good look to figure it out.
Old 10-13-2012, 09:49 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Wow, that sounds like it is inside the transmission. I am guessing it is a failed input shaft bearing. To check for transmission problems, drain the transmission oil into a pan, and inspect for metal pieces and filings.
If you find a lot of metal in the oil, reach around and check the thickness of your wallet.
Alpinweiß
E46, E83, E90 (all with three pedals)
BMW CCA member
help advice needed, input shaft bearing, throw out bearing, tob
