Old 10-08-2012, 09:34 PM
midnitemyst midnitemyst is offline
Mein Auto: 528i
Window not rolling down - motor or regulator?
So I went to roll down the passenger window and never had an issue before. I pressed auto down and it simply didn't go down. I heard a noise like it was stuck or something. The motor seems to roll down about a third of the way because after I press down for a bit, I can push the window down manually. It won't go past about 1/3 of the way down though. But then if I press up, it will roll back up fine.
So my question is, does this sound like a regulator or motor issue? Maybe a gear in the motor went bad? It's hard to tell and I've searched but couldn't find anything very similar.
Thanks for your help guys
Old 10-08-2012, 09:39 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Sounds like a regulator problem. You'll need to open the panel to check.
Search for regulator replacement.
Old 10-08-2012, 09:44 PM
Mein Auto: 528i
Yeah I am going to have to do it next weekend and see what I can find out.
Happen to know anything I should look for or any procedure to single out which it is?
Thanks for the help
Old 10-09-2012, 06:34 AM
tmvE39/E53/Z32's Avatar
Most likely the cable gets off track or the clip is broken. Replace the regulator. Pretty common problem for bimmers made in that era.
Old 10-09-2012, 10:13 AM
Mein Auto: 528i
If its just the clip, I remember reading someone was able to order just the clip. When I take it apart, I'll see what needs to be done but something definitely needs to be replaced because some people think they fixed it and it just happened again later on.
Old 10-09-2012, 11:15 AM
It might even just be loose:
- One user's experience with diagnosing the front left driver door window regulator (1)
I need to put locktite on mine.
Old 10-09-2012, 02:03 PM
Tiko530 Tiko530 is offline
Mein Auto: 2003 530i
Sounds like the regulator to me.
Had my front passenger regulator go out recently and replaced the whole thing. I don't think its worth trying to repair it because it seems to be a fussy part and will likely go bad again soon after a diy repair, your best bet is probably to replace it.
P.S. - Don't use the $35 dollar aftermarket ones on eBay, bought one for mine and it went bad 20 minutes after install while i was still testing it. Merchant was nice enough to send a full refund with shipping too but I learned my lesson to go with OEM parts.
Old 10-09-2012, 05:39 PM
Mein Auto: 528i
Yeah I plan to buy OEM regulator if it turns out to be that which I highly believe it is. If it ends up being the motor for whatever reason, that's something I might be more comfortable with buying aftermarket because it doesn't have to be as precise. Just needs to connect and turn. Correct me if I'm wrong
Old 10-14-2012, 09:57 AM
Mein Auto: 528i
Fixed
Okay so it was beautiful yesterday so I opened up my door and found the issue. It was the regulator but not in the way I was expecting. One of the cable guides got bent and so the cable went over the guide preventing the piece from rolling down the track. You'll see what I mean in the picture. Because of that, the grip that holds onto the window came loose. Realigned the cable guide, sanded it down just a bit to take the rough edges off, put some grease on the tracks, reattached grip onto the window and everything is working fine again.
The only issue I have now is the window slows down at a certain point and takes longer to go up in general than all my other windows. Could either be misalignment or motor, not sure. Either way, its working again without having to replace any parts.
