Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 04-22-2012, 07:45 AM
WG330i WG330i is offline
Mein Auto: 2001 330i
First DIY complete!
Thanks so much for this DIY thread. Multiple posts lead to my executed job. The visual aids were great and the follow up replies added great added details and tricks. Never get rid of this DIY thread.
Old 04-24-2012, 08:30 AM
majordavehan817 majordavehan817 is offline
Mein Auto: 325ci Convertible
Thanks guys for keeping this post up. I used it to fix my windshield washer. I had done the replacements but it still din't work. I was getting ready to try the cavitation method but found that the hose was kinked. I fixed the kinked hose and it worked perfectly!
Old 05-18-2012, 07:29 PM
Ky325iMan Ky325iMan is offline
Mein Auto: '03 325i
This is indeed a great DIY post I replaced mine today and it only took about 10 minutes....Piece of cake! It just amazes me how much a stealership tries to charge people for doing something so simple.....
Old 06-27-2012, 06:47 PM
wil137 wil137 is offline
Mein Auto: 2003 BMW 330i
Thanks for this post...i just changed my pump and I feel liberated and not binded to the dealer prices.
Thanks Man!
Old 07-01-2012, 03:57 PM
phedrick phedrick is offline
Mein Auto: 2003 325 xi
I replaced the headlight washer pump on my 2003 325xi, and in the process I damaged the white nylon or plastic connector that attaches to the hose, that goes out to the nozzles, and fits to the pump. I just hate to have to go to the dealer for a replacement. Does anyone know where I can find the part number, and where besides the dealer, I can find one?
Old 07-16-2012, 04:16 PM
3-2-5-i 3-2-5-i is offline
Mein Auto: e46 325i
my filter was clogged so i cleaned everything out and now it shoots washer fluid straight over the car, any way to turn down the pump or change the angle?
Old 07-27-2012, 10:34 PM
eurovortex eurovortex is offline
Mein Auto: 2003 325xi
Question in regards to DIY, wiring help
I have not attempted this yet however based on the writeup I can see I am well capable (considering I was able to change my breaks etc).
My windshield sprayers stopped working, car was sitting i driveway for 3 months with occasional 2 times a week start and.drive around the block. It stopped spraying the fluid. So I check the reservoir, it isfull. Naturally next i check the fusebox (found reference on that litte fuse chart stating "windscreen washer system" no. 49,52,59 with 5amp 30amp 30amp respectively. I tested all three lil light turns out so I'm all good with fuses.
I would appreciate if you can help me narrow it down even more. I do not want to remove the pump if hoses are clogged. I have not tried the trick with "sprayers and needles" as in poking the spraying hole. I must admit a lot of fuzy stuff and debris fell on it over the months, but i would not think it would clog so easily considering the tiny size of the hole would it?
It seems that previous posters all had washer pump leaks. Does it always leak? And would a wusher pump cause the washer fluid tank to leak out? Because mine is full.
Lastly, if I should check the hose that runs from reservoir to the actual sprayers, or from the water pump to the actual sprayers, do I have to remove the tank to get to the house? How to check the clogged hose? You mention removing that part and trying to squirt. What should I do based on my info, I am a newb. I plan on doing the cheap pump trick but want to make sure it is not a hose.
Also, last resort if it is the pump how to do you properly wire the cables? Does it mean it does not just plug in? I have wired my speakers before in the door with black tape, but this is under the good and I want to seal it off properly not to cause future electrical problems. Any hints appreciation on that as we'll -id especially appreciate general writeup for connecting two wires with some kind of plastic cap, dunno never did it the right way and this time I want to do it. Other thant car runs good. 2003 325xi
Old 07-28-2012, 03:10 AM
howlinjags howlinjags is offline
Mein Auto: Z4M
When I had the problem, the fluid would very slowly leak out from the defective pump. And, again, I bought the pump from the BMW dealer - way over priced, but so simple and quick to replace.
Old 07-31-2012, 12:23 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Thumbs up
Same set up on the X3. I got mine on Ebay $10.95 OEM shipping included.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Matts-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Matts
Old 10-14-2012, 01:27 PM
RHDB RHDB is offline
Mein Auto: 2003 BMW 325i
I finally got around to doing this repair today. I bought the TAAP Corp pump from Autozone and the wires are as posted earlier in this thread = connect the blue/yellow one to the black wire and the blue/red to the brown. The pump from autozone contains to two wire taps to help make the connection. If you have never used them before, here's a link to a quick video on how to connect the wires with them:
Old 10-26-2012, 10:45 AM
330soon2b's Avatar
330soon2b 330soon2b is offline
Mein Auto: '04 330i ZHP
I seem to be experiencing this problem. Wipers activate, but no washer fluid from either headlamp washers or the winshield washers. Do you I need to replace more than one pump???
Titanium Silver '04 330i ZHP | 6 SPD | Black Leather | BT | Moonroof | Xenons | Silver Cube | CP | XM Radio | RE Clutch Stop | X-Pel ClearBra | UGDO
Similar Threads
OEM Washer Fluid Plaz General BMW 122 12-13-2008 11:56 AM
New Info on e46 M3 Bearings/oil pump service bulletin MUST READ TGray5 M Series 5 12-03-2007 09:08 PM
Windshield Washer Fluid - Vanishing - matt_328is E36 (1991 - 1999) 3 03-05-2005 06:35 AM
Replacing Smog Pump/Secondary Air Pump - DIY? BrettInLJ 5 Series 3 02-08-2005 03:57 PM
clear windshield washer fluid found..... 31st330i 3 Series / 4 Series 1 06-03-2002 12:13 AM
