E30 (1982 - 1993)
Old 10-11-2012, 03:08 PM
Bimmerkid325i Bimmerkid325i is offline
Mein Auto: 1991 BMW 325i E30
Windshield wipers sticking
1991 325i. My windshield wipers are sticking when I have the intermittent wiper mode selected. The one that had a time delay and not constantly wiping. What would cause the wipers to stick. Like make half a wipe and I'd have to switch to full on mode to get them to move? Windshield motor sticking? Please help thanks!
Old 10-11-2012, 04:00 PM
downhiller's Avatar
livin large
motor going bad, have a bad relay. thats all i can think of
Old 10-12-2012, 08:04 AM
Thanks downhiller, do you know where the wiper motor relay is located? How would I know if it's going bad. Secondly is replacing the motor a difficult job? I don't even know where it is. I'm fairly mechanical inclined, ive done a few head gasket/top end rebuilds on a number of different models including my e30.
Old 10-12-2012, 12:55 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Its a PITA. Look on your firewall you'll see a removable plate. Behind it is where your wiper motor is. There's three bolts that hold it on and one bolt for the linkage arm. I replaced the wiper motor on mine, also I replaced the arm that connects the motor to the linkage and the bushings. Its worked fine for 6 months now but I now have the same problems you do. It just started last week. On the first click up on the wiper switch it will go half way and stop. So if I push down on the switch for a quick wipe it'll do the same thing. But if I put it on level 2 or 3 on the switch they work fine. Im guessing relay or if we have resistors could be that... Im still lookin into this.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 10-12-2012, 01:00 PM
Newman271's Avatar
That Guy
http://www.realoem.com/bmw/showparts...85&hg=61&fg=45
thats your motor and linkage setup
http://www.realoem.com/bmw/showparts...38&hg=61&fg=25
Looks like there is a interval control unit
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 10-12-2012, 01:16 PM
Newman271's Avatar
That Guy
I have to take apart my steering column to get to my turn signal switch to clean the contacts. Im thinking about cleaning the wiper switch contacts too.. I'll keep you updated to see if it makes a change.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 10-12-2012, 06:14 PM
BMWFatherFigure's Avatar
Old School
Could also be park mechanism as the motor is started by a pulse and then relies on the park circuit to complete the cycle. Test the park.
Current:
E38 Parts Car
Previous:
Old 10-13-2012, 09:27 AM
I have a 5-speed not the automatic
Old 10-13-2012, 09:32 AM
downhiller's Avatar
livin large
hes talking about the wiper motor. that pulse is what starts and stops the motor
Old 10-13-2012, 10:49 AM
Ok thank you for the clarification. How would I test the park mechanism and where is it located? Is it part of motor?
Old 10-13-2012, 09:05 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
I have had this problem of the wipers starting to stick on intermittent. I think it is dirty tracks in the motor. The connection is made on a circular metal disc with a gap in it and grease + dirt can break the connection. I just put my wipers of full speed for a few minutes and it cleared it. I guess it is still lurking around the corner to cause me trouble again one day, just like my occasional sticky door lock :/
Old 10-14-2012, 08:46 PM
Old School
+1 tim96
Current:
E38 Parts Car
Previous:
Old 11-29-2012, 02:23 PM
I don't know why but I just left the wipers on with the intermittent setting and dealt with them sticking. They gradually got better and now work fine. Don't know what happened, o well.
Old 11-29-2012, 11:31 PM
Old School
The track cleaned it's self - just like tim96 said.
Current:
E38 Parts Car
Previous:
