Old 10-08-2012, 12:45 AM
fahadcom fahadcom is offline
Mein Auto: BMW F02 2013
Coding 7 series F02 2013?
Hi,
I have 2 questions:
1-I'm wondering If Is it possible to code my 7 series 2013 with PSdZ Data v.47.5?
2-Is It possible to activate the acoustic signal for locking/unlocking through coding? I Have the Alarm system (302) it's already Installed, But this option is not appearing in the IDrive.
Thank you in advance,
Name:	No option for Acoustic signal for locking unlocking.jpg
ID:	344746   Click image for larger version
Old 10-08-2012, 10:18 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by fahadcom View Post
Hi,
I have 2 questions:
1) Yes, you can code you F01 with E-Sys and 47.5 PSdZData.
2) Should be. Code HU_CIC / ACOUSTICAL_LOCK_CONFIRM = aktiv
Old 10-08-2012, 10:55 AM
Nice. I will try and i will let you know when I received my ENET Cable next few days...
Thank you
Old 10-15-2012, 02:30 AM
1)
Sorry I have a Noob question
Now the Module is "HU_CIC" right ? what about the Section ? Could u tell me what is the section?
Thank you,
Old 10-15-2012, 04:52 AM
Thank you,
On the F10, it is in 3000 HMI.
It much easier to just use the search window at the top, and paste the value (ACOUSTICAL_LOCK_CONFIRM) into it. It searches Top Down though, so make sure you highlight the very first entry in the ECU before searching, and DO NOT include any trailing spaces after the value.
Old 10-15-2012, 05:17 AM
Hmmm, I will use the search window. By the way I'm still waiting to receive my ENET cable...
Old 10-15-2012, 05:22 AM
These things differ some by chassis, so if you can't find "ACOUSTICAL_LOCK_CONFIRM" exactly, trying searching only on "ACOUSTICAL" or "LOCK", etc.
Old 10-15-2012, 05:34 AM
You know. I Tried to activate the acoustic signal for locking/unlocking through my dealer but they replay to me with this.
customercare.me@bmw.com
Oct 3 (12 days ago)
to me, frank.zauner
Dear Mr. Alibrahim,
Thank you for your email which was forwarded to us from BMW in Munich.
Kindly be informed that the Acoustic signal for locking and unlocking cannot be retrofitted. The video shows that the car is from the US market where this system is available but not in the European market. The alarm system mentioned in your email is an anti theft alarm. In the European specification, only the visual indication for locking and unlocking is available.
If you have any further enquiries, please do not hesitate to contact us.
With kind regards,
Jaxeena Mahesh
BMW Group Middle East
Jaxeena Mahesh
Customer Care
Phone: +971-4-3132-651
Fax: +971-4-3300-126
mailto: customercare.me@bmw.com
Url: http://www.bmw-me.com
Hope that's I can activate this option through coding
Old 10-15-2012, 05:42 AM
Oct 3 (12 days ago)
to me, frank.zauner
Dear Mr. Alibrahim,
With kind regards,
Jaxeena Mahesh
Jaxeena Mahesh
Customer Care
That is true that the anti theft alarm is needed. I don't know if you have it or not. Maybe you have it, and it is not enabled. To enable it too, set HU_CIC/ 3000 HMI / DWA = aktiv
Old 10-15-2012, 06:34 AM
Yes I'm sure, I have the Alarm system "anti theft alarm" Code (S302A). And it's working. But the option for acoustic signal for locking/unlocking is not showing in the IDrive
Old 10-15-2012, 06:37 AM
Then you should be good to go.
Old 10-22-2012, 04:51 AM
Finally I activated the acoustic signal for locking/unlocking successfully, But the sound signal is coming only from the right corner of the rear bumper. In fact I don't know if it's normal or not.
I also successfully coded:
1-Disable seat belt reminder - driver.
2-Sets car's Auto Start/Stop function to start in the last used setting.
3-Speed limit information.
4-Disable TV and DVD Speedlock.
Thank you shawnsheridan
Old 10-22-2012, 09:38 AM
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5er GT 535d
3-Speed Limit Display.
how did you get the acc. signal coded? with "ACOUSTICAL_LOCK_CONFIRM" ?
because i had to code:
FZD/3002/Akkustische Quittierung Schaerfen
FZD/3002/Akkustische Quittierung Schaerfen mit Klappenbetrachtung
FZD/3002/Akkustische Quittierung Entschaerfung
FZD/3002/Lautstaerke Akk. Quitt. tageszeitabhaengig
Regards
2010 BMW 535d GT
Old 10-22-2012, 10:38 AM
Regards
Yes with "ACOUSTICAL_LOCK_CONFIRM"
Old 10-22-2012, 11:30 AM
strange... what are your values then in the settings above? in the CAFD of FZD?
Is your checkbox now functional?
2010 BMW 535d GT
Old 10-22-2012, 11:40 AM
NO it's not in CAFD of FZD, As i remember it was on HU_BNT or something like that "use the search window" , Any way I will check for you tomorrow, sorry ....
Old 10-23-2012, 01:01 AM
Yes I checked today in my car it was in HU_BNT As I told you. About the checkbox in Idrive yes it's functional.
Be sure that you have the Alarm system "anti theft alarm" Code (S302A). If you don't know check out this web: http://bmwvin.com/
Old 10-23-2012, 01:43 AM
dear fahadcom
my signal is working, but i did code it with these settings to set "aktiv":
the "ACOUSTICAL_LOCK_CONFIRM" is just the checkbox in the CIC. Which i also coded now and really good to have, for some reasons when you have to shut of the signal.
my question was, what are your entries in FZD to see if these settings have to be on "aktiv" or not for the signal functionality.
Thank you.
2010 BMW 535d GT
Old 10-23-2012, 02:00 AM
Actually I don't know what you mean by FZD, because I'm new in coding. But what i did I brows "HU_BNT" then search for "ACOUSTICAL_LOCK_CONFIRM" then chose edit then I chose "aktiv" after saveing this setting, I started the Idrive I put a check mark on acoustic signal for locking/unlocking. That's it
Old 10-23-2012, 02:37 AM
what i mean is:
In the ECU "FZD" there are these settings:
what would be nice to know is, if the settings were already on status "aktiv" or if they are "nicht aktiv" but the singal works anyway.
2010 BMW 535d GT
Old 10-23-2012, 02:39 AM
what i mean is:
It was "nicht aktiv"
