Old 10-12-2012, 11:28 AM
blackmagice46 blackmagice46 is offline
Mein Auto: BMW 318i E46
Bmw 318i e46 wont start help please
Hi everyone. iv recently purchased a BMW 318i E46 5 door. after a few weeks of driving it i noticed that it was leaking oil from the oil fillter housing, so i replaced the gasket and the oil filter etc... as you all probably know to get down to the gasket you have to remove the altinator/air filter atc. iv put all the parts back in reverse order and now the car wont start. the car has never had any starting problems before to my knowlage, only that some time the starter motor would stick on first turn but then it would be ok. any idea please people need it sorted asap thanks
Old 10-12-2012, 12:17 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Is the engine cranking over ? At normal speed ? When you turn the key to Position 2, do you hear the "whirring" noise of the fuel pump priming the system ?
Have you read the E46 Wiki ?
The road goes ever onward....
(R.I.P. Jever)
Old 10-12-2012, 12:21 PM
no engine wont crank over, all that happens is i turn the key and it does a clicking sound. all electricals seam really slow and light dim!no i havent yet.
Old 10-12-2012, 12:27 PM
hexy27's Avatar
hexy27 hexy27 is offline
GO FLYERS!!!
Mein Auto: 2002 330i
Sounds like it could be as simple as a dead battery
Old 10-12-2012, 12:29 PM
Thats exactly what i thought but why would it just go like that after disconecting altinator and battery
Old 10-12-2012, 12:46 PM
Fast Bob's Avatar
Keeping it surreal
Batteries often die with little or no warning....happens all the time.
(R.I.P. Jever)
Old 10-12-2012, 01:36 PM
papalou13 papalou13 is offline
Mein Auto: BMW 325CI
Try to jump the battery or replace it, then you will know if your alternator drained it.
Old 10-12-2012, 02:43 PM
Thanks everyone for replying. i shall try and put some leads or a replacment battery in her tomorrow and let you know how it goes. once again thanks
Old 10-12-2012, 09:29 PM
Mein Auto: '04 330Ci 6-speed
If not battery, then next consider a starter problem.
Old 10-12-2012, 10:47 PM
lgr122 lgr122 is offline
Which makes me think, that should actually check how old is my battery...
lots of things are still according how previous owner put them so i don't know for sure myself.
Old 10-15-2012, 07:42 AM
Put the battery on charge this morning and the car just started up. thanks for all your help lads.
OH and how do i add a profile picture on here so i can show off my car haaa
Old 10-15-2012, 08:16 AM
Pictures of your car can be added in "My Garage", or optionally going into your profile (click your name) and then add album.
Older members may correct me if i adviced bit wrong.
Old 10-15-2012, 01:42 PM
Anytime Lad
Old 09-17-2015, 02:23 PM
Kris318i Kris318i is offline
Mein Auto: 318i 2.0
Hi folks, just joined this forum , bought a 318i 2.0 last week, running great until bout an hr ago , I went for an hrs drive stopped at shop an she wouldn't start again, she's clicking like mad tryin to start but no Go, a passer by put the leads on an away she went, does this sound like a past its sell by battery ? Thanks
Old 09-17-2015, 02:57 PM
Fast Bob's Avatar
Keeping it surreal
Sounds like a failing battery. Possibly dirty/corroded cable connections. Check & clean everything possible. Where are you located, somewhere outside the US ?
(R.I.P. Jever)
Old 09-17-2015, 03:05 PM
Mein Auto: 318i 2.0
Yes mate I'm in Ireland, I checked the terminal connections and all are fine , it was in a lock up for 2 months til I bought it last week, though all week it's started first time until tonight, I did notice it a bit sluggish but she still started no problem, I'll put a new battery in tomorrow an see what happens, thanks pal
Old 09-17-2015, 03:15 PM
Mein Auto: 318i 2.0
I'll go with the new battery an take it from there, thanks for the info guys
Old 09-18-2015, 02:16 AM
Mein Auto: 318i 2.0
Bmw lights at back of car symbol
Guys Wat are the lights at the back of the car symbol inside the car ? Just appeared this morning, thanks
Old 09-18-2015, 07:54 AM
Papalou13
back lights must be out, it could be burn out bulbs, if not? it could be short on your harness.
Old 09-18-2015, 07:55 AM
Not starting, but clicking? Start with replacing battery and go from there.
Old 09-18-2015, 07:59 AM
Mein Auto: 318i 2.0
Yea took out cluster an the harness wire was caught in the plastic, thanks guys , been a while from I've had a Beemer so gettin to grips with it again, as for the Battery problem I put it on a multi meter in work today an not great voltage, before *****in another battery I got it properly tested in garage an soon found the alternator is charging it wen driving but not wen idling ,, so will replace it thanks again guys
