Old 10-15-2012, 04:21 AM
Shoalin Shoalin is offline
Mein Auto: BMW 330i 2003
car keeps overheating after new parts
The belt had broke in my car. So I figured since I had to replace the belt I would replace some other parts too since I was in that part of the car.
Replaced: water pump (geba), thermostat, upper radiator hose, water pump pulley (aluminum), serpentine belt, AC belt, tensioner pulley, idlery pulley.
After I put the car back together I filled up the coolant tank with coolant waited and drove the car. The car overheated after 5 miles had to keep it parked a local parking lot till it cool down. I couldn't drive more then 3 miles without over heating.
What did I overlook? What needs to be done?
Ignorance breeds dependancy; knowledge gains you freedom.
Old 10-15-2012, 04:30 AM
hexy27's Avatar
hexy27 hexy27 is offline
GO FLYERS!!!
Mein Auto: 2002 330i
You need to bleed to cooling system to get the air out. Instructions for the procedure are in the WIKI
Old 10-15-2012, 04:36 AM
Thank you so much.
Old 10-15-2012, 06:21 AM
While I was bleeding the line the bleeder screw broke off, Ugh! I paid alot for that upper radiator hose part! I found out that I have a damaged radiator. So, I have to deal with that. Looking for a DIY for that now.
Old 10-15-2012, 06:31 AM
bimcwe bimcwe is offline
XIL
Mein Auto: 2002 325xi
http://forum.e46fanatics.com/showthread.php?t=543989
Hope that helps.
Dreaming of the ///M.
Old 10-15-2012, 07:31 AM
Thanks!
Old 10-15-2012, 09:48 AM
mickey513 mickey513 is offline
Send a message via AIM to mickey513
Mein Auto: e46
The plastic screw on the hose is replaceable and so separately, sold at the dealer only or a larger online specialty auto part store. I'm not talking about Advace Auto, Autozone, etc,
I broke mines the first time I bleed the systems years ago ... my first thought when I broke it was F@UCK. What did I do now.
Old 10-15-2012, 10:25 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
I believe there's actually a brass replacement for the plastic bleeder screw. Maybe oembimmerparts.com would have it. Give them a call, the owner there (Max) is incredibly helpful.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 10-15-2012, 12:11 PM
That's a relief! But how do I get the remaining part of the plastic screw out of the hole? Hmm.
Yeah, I know the sentiment.
Old 10-15-2012, 12:36 PM
Whew! getting the remaining screw out was painless. I was all prepared with a kitchen paring knife but remaining part of the plastic screw unscrewed easily without much effort.
I am sooooo relieved. Thanks so much for letting me know about the replacement screw, I just ordered one from the dealer for 5 bucks. This saved me from having to buy another hose!!
Old 10-15-2012, 12:57 PM
Scott ZHP's Avatar
We want the Lion!
Or you could just remove the one from the old hose. You do keep the old hose in the weed compartment just in case, right?
Old 10-15-2012, 01:59 PM
Brillant! Why didn't I think of that?! In fact I did keep the old parts just in case of who knows what.
Old 10-15-2012, 02:26 PM
mrg325i mrg325i is offline
Mein Auto: 01 330Ci MT
Drive the car up on a set of ramps and turn the heat on all the way up to circulate the water in the heater core. Turn the car on and try to bleed the system again. This should remove all of the air out of the system.
You do not want to have any air bubbles in the system.
Old 10-15-2012, 02:41 PM
Thank you!
Old 10-15-2012, 09:27 PM
Mein Auto: '04 330Ci 6-speed
You did order a brass bleeder screw, no?
And are you using www.furiousmethod.com to shop for the best price for parts?
Rad is under $150 for instance.
