E36 M3 (1995-1999)
Old 12-04-2011, 08:40 PM
AlpineWhiteM3 AlpineWhiteM3 is offline
Mein Auto: 1995 M3
Stomp Test Help?
Hey Guys, I have a May 1995 M3 and I've tried the stomp test a few times but nothing seems to happen. The "check" light came on last week, so I did a bit of reading to haven't come across anything specific for my model.
Also can somebody clarify if the May 1995 M3 was 286 HP or 295 HP, when looking for info I found an article that says the 1995 M3 is 295HP but that was the 1st time I'd read of the extra horses...giddee up.
Any info would be appreciated?
Old 12-07-2011, 04:13 AM
rrsperry's Avatar
rrsperry rrsperry is offline
Really Senior Moments
Mein Auto: ///M3 sc
Since you are in Oz, you have the S50b30. 286Hp. (at the crank, about 230-240 rwhp)
Are you sure you are doing the stomp correctly? I'm not even sure that tthe stocp test even works on the Euro engine managment system. But..
Turn key to on, then immediately
Fully press gas pedal to the floor 5 times withing 5 seconds.'
Make sure that the pedal goes all the way to the floor, no carpet or mat blocking any travel? Check that the throttle linkage is letting the tb's fully open. (adjusted properly...
No matter where you go, there you are.
Old 12-07-2011, 05:50 AM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Then after the first code is displayed, punch the pedal 5 more times in 5 seconds revealing a new code until you get to 1000.
Then holding the pedal down for 10 seconds will clear the codes.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 12-07-2011, 11:34 AM
rrsperry's Avatar
Mein Auto: ///M3 sc
No, there is no need to do any more stomping. it will cycle through all the stored codes by itself. Then repete the cycle.
Old 12-07-2011, 07:21 PM
crisscross's Avatar
I have yet to see that happen on either of my e36's, but I guess I could be wrong...
-Alan
-2000 F250 V10
Old 12-07-2011, 08:08 PM
X3-terrestrial's Avatar
Aficionado
What in heaven is "the stomp" and what is it for??
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 12-07-2011, 08:49 PM
crisscross's Avatar
On the OBD1 e36's you can "stomp" on the pedal 5 times in 5 seconds after turning the key on read the stored check engine light codes.
-Alan
-2000 F250 V10
Old 12-07-2011, 09:07 PM
Mein Auto: 1995 M3
I've tried 2 different occasions(3 or 4 times each), stomped 5 times quickly as soon as the dash lights come on, nothing seems to happen.
How would I know if it's OBD1 or 2 that I have?
Might orange light just says "engine" not engine check or anything and I looked at numerous YouTube vids and no other dash has just the "engine".
Old 12-08-2011, 03:58 AM
rrsperry's Avatar
Mein Auto: ///M3 sc
Try to contact Mr Blond on Bimmerforums. I think he lives in Sydney, and had a 95... (not that Sydney is close to you or anything. I mean Oz is a VERY big country. I was there in 2010...)
Old 01-04-2012, 07:15 PM
Aficionado
Thanks! Your response came handy a couple of days ago, got a CEL, car felt sluggish on the lower end, did the stomps and got 1221 (O2 sensor bad) installed a new one and problem fixed! Light went away about 5 minutes after driving.
-Mario Andretti.
___________________
Old 10-16-2012, 07:34 AM
BMWEnthus BMWEnthus is offline
Banned
Mein Auto: 89 325i
STOMP only works on US models
Old 12-10-2012, 09:28 AM
m3racr m3racr is offline
Mein Auto: 1995 E36 M3 Coupe
Where are the codes displayed after performing the test? Do I need a legit BMW OBDI code reader?
DMAN
Old 12-12-2012, 08:52 PM
Aficionado
No, the actual check engine light blinks and pauses four times, count the blinks in between and that's your code. I think YouTube has some videos.
-Mario Andretti.
___________________
