Old 10-14-2012, 05:22 PM
Pinki-773 Pinki-773 is offline
Mein Auto: 03- 743Li
03 745li Angel eyes
Hello am a newbie here did some research on here but could not find my answer Am hoping someone could help me out I just recently bought a 03 745li and installed some new Angel eyes but no matter what I try the is no way for me to only have the Angel eyes on it's eather the the angel eyes and hid's or the regular low beam head light and angel eyes.
So my Maine question is how can I only turn my angel eyes on and not the other lights?
Old 10-14-2012, 05:28 PM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
It should be one click to the right on the headlight switch.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-14-2012, 05:33 PM
So the switch shoud be in the 12' o'clock position when I put it the only my low beams are the angel eyes are off all the way then?
If am understanding you?
Old 10-14-2012, 06:44 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
So in the pic, the switch is at 12 o'clock position,like pmpn8ez said one turn to the right which would be at the 1 o'clock position... you will have your park lights and angel eyes illuminated...also in this position you can turn on your fog lights as well..
ID:	345690   Click image for larger version
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-15-2012, 05:43 AM
Yeah eather way I put it my low beams come on, could it be my wiring or something?
Old 10-15-2012, 05:58 AM
Yeah, It's possible the previous owner had an issue and wired it differently. Maybe someone else can chime in with other things to check.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-15-2012, 06:03 AM
Do you know if I dissconect the low beams will it throw me any errors on the dashboard
Old 10-15-2012, 06:38 AM
From where? Most likely. This car throws errors on the dash for everything.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-15-2012, 08:57 AM
I was thinking down where the light is it self or do u know if they have a fuse for the low beams?
Old 10-15-2012, 10:41 AM
I'm sure there is one. I found this in a different thread
ID:	345801   Click image for larger version
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-16-2012, 09:21 AM
Jerry 745Li Jerry 745Li is offline
Mein Auto: 03' 745Li
I believe the OP is seeing the DRL's, which are illuminated in the 1 o'clock position. So those ugly yellow lights throw off the cool LED halos. To disable the DRL's you need to take it to a BMW shop or get the proper software and cables and do it yourself.
Jer
I don't have all the answers, but I can do one helluva Google search!
Old 10-16-2012, 08:08 PM
Jer
So when u put it to 1oclock only the angel eyes are supostu be on do u know how mutch that fix might cost? Cuz when I put mine there my ugly yellow lights are only on?
