Old 09-04-2012, 04:32 PM
blulite blulite is offline
Mein Auto: 550i
Automatic Hold (A Hold)
Is anyone aware of a coding option to remove the requirement for the seat belt to be engaged before allowing for "Auto Hold" to be engaged?
I would like to be able to start car, disengage the parking break (ie hit the A-hold button), then start driving. Once underway I put on my seat belt.
Jeff
2011 550i Dark Graphite/Oyster Black, Sprt Trns, SP, PP1, PP2, DAP, CP
Old 10-16-2012, 10:51 PM
tester00 tester00 is offline
Mein Auto: BMW 335i E92
Automatic Hold
Hi,
Can we code the Automatic Hold ( A Hold) to Auto On, so if we start the engine and the automatic hold is always on ?
Old 10-17-2012, 03:02 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by tester00 View Post
Hi,
Not that I know of. It may be there though, undiscovered.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 12-31-2012, 11:02 PM
djsaad1 djsaad1 is offline
Mein Auto: range rover
In Kombi there is a predrive ahold setting that is set to not active, I would guess if you set it to active it should start the car with automatic hold. I will give it a try tomorrow.
Old 12-31-2012, 11:21 PM
ImSW1 ImSW1 is offline
Mein Auto: F10
If it's sitting in Kombi...more than likely it's the pre-test of the system and temporary initiation of the indicator in the cluster. I would expect for you to see the "A-Hold" indicator come up in the Kombi during the start-up procedure rather than it automatically activating A-Hold. These are just my thoughts, don't let them stop you from giving it a try.
Sean
Old 01-01-2013, 07:21 AM
Sean
Yep, you were right. That is all it did.
I will keep looking.
Old 02-02-2013, 09:15 AM
KAcoding KAcoding is offline
Mein Auto: BMW
Does it work with you ?
Old 04-17-2013, 11:47 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
Any updates?
