E36 (1991 - 1999)
Old 10-17-2012, 10:23 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
from my understanding its built into the fuel pump. but BMW dealers an external check valve. for like less than $20 iirc
-Dino
Old 10-17-2012, 10:26 AM
jwrape jwrape is offline
Mein Auto: 96 Z3M (M S52 conversion)
So if I were to install one in the Fuel feed line then it would solve the issue?
The BMW ones I have googled look like this
Old 10-17-2012, 10:34 AM
BMRfanatic's Avatar
From the 2nd video i posted on the 1st page that doesnt look like it.
skip to 9 mins and thats the check valve.
have you done all the tests to narrow it down to the valve?
-Dino
Old 10-17-2012, 10:42 AM
Well, when I did my pressure check as you did in your last video, my gauge looked just as yours did. When it was sitting there it would drain down, when I clicked the key to the 3rd click it was around 20+ psi, when I started it would sit around 50psi...
that with the exact same starting issue you are having and I think it's the same problem.
Other troubleshooting: Checked for Fuel Injection pulse when starting, changed my Fuel pump out for one with 40k miles on it. Unfortunately it did the same thing. Switched back my old pump back in. New Crank position sensor, New Fuel Filter, Reset Computer, checked Relay(Main and Fuel Pump).
My starting issue is spiratic. Sometimes it starts perfectly on the first turn over. The other times it takes 3 spin overs with 3 key cycles and then it starts OR the one that you are having where it spins over and over and over for more than 20+ spins and many key cycles and no start and then somewhere in there it starts and runs perfect.
It makes me feel like it might not start. It's my wifes fun car and I hate for her to feel stranded.
Old 10-17-2012, 10:49 AM
Ok can you get this valve locally or do I need to order it from somewhere?
BMW 16149068988
Old 10-17-2012, 11:15 AM
BMRfanatic's Avatar
i see. when i called the dealer near me i had to go order it then it would arrive in 2 days. not sure if itll be different where you are
-Dino
Ok, I see a lot of posts around Google saying it's discontinued, hpoefully I can get one
Old 10-17-2012, 11:24 AM
BMRfanatic's Avatar
yeah i think its an order only part now from the dealer
-Dino
