Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 10-17-2012, 11:29 AM
Assimilator1 Assimilator1 is offline
Mein Auto: BMW 330d E46 11/2001
Who said the original oil isn't available??
I bought the genuine Esso stuff from a VW parts wholesaler (much cheaper than BMW!) a couple of months ago .
Team Anandtech - Folding@Home, DPAD, SETI & MW@Home
Old 01-22-2013, 09:01 PM
AlboBMW's Avatar
AlboBMW AlboBMW is offline
#422323
Mein Auto: '01 325i
A big thank you to all of you who have participated and helped make this a great thread. Thank you especially to OP for his research and hard work.
I did this job this past weekend, and I can't tell you how nasty and grimy the "lifetime" fluid was. I got so dirty changing the fluid that I didn't have time to take pics. My cas has 162K miles. I noticed smoother shifting after the fluid change.
I used Valvoline MaxLife.
Once again, thank you all.
Best mod - E46 Wiki - Dead Man Driving
Old 01-22-2013, 09:08 PM
shroomer shroomer is offline
Mein Auto: 2001 BMW 330i
Totally.
I have 154000 miles. I did an oil and filter change at about 70k miles. I drained and filled a few times since then.
As far as the tranny goes, all has been good.
I have used Valvoline MaxLife everytime.
Apparently I am getting a bad torque converter seal code. I am curious if the Valvoline caused the bad torque converter seal. Anyone else have this issue with a Valvoline fluid change?
In any case, my tranny is still good. So that's cool. I just erase the code with my scanner and it stays gone for several hundred miles. So I guess I'll just drive until I have a real issue.
But thanks for this thread!!! Well done.
Old 01-23-2013, 08:51 PM
AlboBMW's Avatar
#422323
Mein Auto: '01 325i
Originally Posted by shroomer View Post
Totally.
Sounds like a common issue from the replies in this thread: http://forums.bimmerforums.com/forum....php?t=1566841
Old 04-26-2013, 12:12 AM
irrogical irrogical is offline
Mein Auto: e46
Transmission warning light
I got the dreaded phone cal from my wife: there's a light on in the dash, what do I do?
It was the transmission fault light, and she limped the car home. I replaced all the fluid I drained out without dropping the pan, and the light went out. In the mean time I ordered a filter, gasket, and new bolts from the dealer.
The filter etc came in this week, and I was planning to drop the pan and do a full change in a couple weeks when the weather warms up some. Unfortunately the car had other ideas, and illuminated the warning light again today. I have done the filter and new fluid (6.5 qts went in, probably 6.25 staayed in), trouble is the warning light did not reset this time. Anyone have any idea how to reset the light? Or better, read the code?
Just to be clear, this is the exclamation point inside the gear next to the D; the service engine soon light is off.
We have a 2003 325 with the ZF transmission, and 105k miles.
Side note, even with the old filter, the drained fluid tonight was much redder than the first set, about 100 miles ago.
Big thanks to T-W for the original post, it was much better than Uncle Bentley's coverage
--roger
Old 04-26-2013, 06:30 AM
tblt44 tblt44 is offline
Mein Auto: vette
The original fluid should be carmel color like motor oil. At least it is on the GM transmissions. The red stuff is ok as long as its designed for your ZF transmission. What fluid did you us
Old 04-29-2013, 06:16 AM
Mein Auto: e46
I used the Valvolene max life fluid - still has the Esso comparability label on the quart bottle; I have a Zf 5HP19.
I called the dealer today on my way to work, I am of course being 'blamed' for changing filter. I told home light was on before filter change, and that mollified them. Apparently my 'codes' are internal transmission faults - ouch!
He couldn't remember what the codes are so of course that's no help to me. Sounds like I'm going to need a good Indy in Boston / Metro-West soon.
--roger
Old 04-29-2013, 06:51 AM
Mein Auto: vette
Is the transmission functioning better now with the fluid change?
A new trans is big money.You may find a shop to get you a used one about 1500 or rebuild yours.
First you may want to try getting the light reset to see if the fluid change helped.
Old 04-30-2013, 09:20 AM
Mein Auto: e46
Codes were 31,35, 36: internal slipping. The input shaft and output shafts are not turning in the proper ratio. Having called a couple people so far, sounds like a new tranny is the way to go cost wise. People don't sound like they want to rebuild a Zf, they just replace it. (That includes a transmission specialty place.). I have prices of 1600 for a used on w/ 6 months warranty and 2950 for a reman with 12 months. Both unlimited miles. I am being told +/- 9 hours labor for a straight swap. Looks like I'm in it for about $4k, which is still less than the dealer wants for the transmission alone albeit with 2 yr warranty
--roger
Old 04-30-2013, 09:23 AM
Mein Auto: e46
Seemed to me like everything was fine until the light came on. I can't tell a difference in how it drives before or after the new fluid or new fluid and filter.
--roger
Old 05-10-2013, 03:29 AM
firefoto firefoto is offline
Mein Auto: 2001 325ic
AT service & coolant lines replacement
When I bought my car, the transmission blew the front transmission seal within a month of purchase. Although not covered by warranty, the seller replaced the transmission with another est 120k trans at no charge. 2 years later the trans coolant line hoses are leaking and need replacement. The hoses were rubbing against the sway bar and were seeping there but were also seeping from the swage fittings on their ends. It looked like an engine oil leak since the fluid was brown. I figured the valve cover was leaking but when we hoisted it, we found no leaks from the engine and lots of trans fluid under the car. Scary since you can't check the fluid level. My oil change service guy wasn't checking the fluid so we could have been low on trans fluid.
I work at an adult career center and had my ASE class do the work. Your description was spot on for the trans service.
Replacing the lines was very difficult. Don't try to do this without a lift. You'll go crazy! Tough to remove the lines and even tougher to install new ones. The quick connects did not disconnect, plastic release collars disintegrated so we had to destroy the retainer tabs in the connectors. Snaking the lines over the rack and around everything else was difficult...but can be done. Install and remove from the rear.
We used Mercon V Valvoline, 6.25 qts. Bought a fluid vacuum hand pump at NAPA for $13 to pump it in. Had to put smaller fuel line hose into the pump hose to fit into fill hole in trans. Remove cap of pump to fill with Mercon. Screw lid back on and pump into trans. Easy but slow.
My instructor is a diesel & HD truck service mechanic and runs a large truck service facility. He is very familiar with transmissions. Said watch out for chunks in the trans pan, are pieces of the lock up plate disintegrating. I had a couple. Said Mercon V is a full synthetic fluid used in all the newer transmissions and the bottle says replacement for Ford trans fluid and Dexron III.
My transmission had a green sticker on it.
Took about 1.5 nights of 3 hours classes to do all this while instructing the students.
The transmission is running perfectly. The car has 140k on it and about 130k on transmission. I will be having the class do transmission service on all my vehicles. After seeing the trans filter almost plugged, and the off color fluid coming out, I believe this condition would have shortened the life of the transmission considerably.
BTW, instructor believes this is a European Ford transmission. The filter had a Ford part number.
Thanks so much for the detail on how to service and fill the transmission! It took about 4 quarts before we started it and another 2.25 quarts after we started, ran through gears and left in idle and neutral.
Old 06-17-2013, 04:56 PM
Augster Augster is offline
Mein Auto: M1A1 Abrams
So the inlet transmission oil cooler line broke and I drove the car approximately 5 minutes/5 miles before truly realized what was happening with the tranny warning light coming on. The dealer wanted $1,200 to replace the oil cooler and busted line, but doesn't know the status of the transmission (they can smell burnt transmission fluid in the transmission). After getting towed back, I'm going to replace the cooler and line myself, but also do a complete filter and fluid change, and just hope for the best.
Since the last meaningful comments on ATF were made between 3 to 4 years ago, with Valvoline Maxlife (Dexron/Mercon) heavily recommended then, if not selecting the more expensive OEM Esso LT 71141 (I have the A5S 325Z tranny). Do these recommendations still hold true (Valvoline Maxlife and Esso LT) as the ATF to use? If Valvoline Maxlife has proven to meet or exceed BMW specifications by now, then I'd go for it.
2003 325i "Plain Jane" SULEV
Similar Threads
E39 Automatic Transmission Fluid Change DIY ANYONE??? e39breyton E39 (1997 - 2003) 90 05-20-2013 09:13 AM
More on the N54 engine/ new transmission mapezzul E90/E91/E92/E93 (2006 - 2013) 5 07-18-2006 08:30 PM
E46 Manual Transmission Fluid Change? Ramps? 2001E46 Do-It-Yourself H.Q. 13 09-29-2005 05:32 PM
brake fluid change on E46 mwette Do-It-Yourself H.Q. 18 04-28-2003 03:06 PM
