X3 E83 (2004 - 2010)
#101
BMW probably uses different suppliers for different model. For instance I think for the E90, Mann supplies it to BMW. Might pick one up for my mother's 325i.
#102
Not sure about Bosch, but BMW filters have the Mann stamp also.
Madurodave My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi Retired: 1998 BMW Z3 Member of BMWCCA! |
#103
What are your thoughts on: http://www.ecstuning.com/BMW-E83-X3-...Kits/ES250700/
I have a 2007 X3 3.0si (btw, is there a difference between si and i or is that just to label the N52 engine?)
#104
Mobile 1 5w - 30 HIGH MILEAGE(???)
Thank you for this oil change walk through. I just changed the oil on my X3 and everything went great. I could not find the 83MM / 16 Flute wrench, so I used on of those strap oil change things. I am going to order one online.
One question, after I poured the oil in I realised I got the Mobile 1 5w-30 HIGH MILEAGE version. My car has 60,000 miles. Will this be an issue? Should I be concerned? Did I screw up??? Please advise. |
#105
I see that oil has extra anti-wear additives as well - not sure if that is at the expense of something else that you would have got in regular Mobil 1 5W30. The 0W40 would have been the best choice as it's the only Mobil 1 that meets BMW standards for long life, high temperature shear stress, and what-not. |
#106
Just changed the oil on a 2007 X3 for my 1st time. I was able to get under the car without a problem with it on the ground. Didn't need my Rhino Ramps which I have for a Toyota. I got the 0W40 Mobil One from Napa in the fall for $5.99/quart and the filter from the dealer. From what I read online at various places, I put in 6.5 quarts. I check the level and got the 'OK' from the computer. I can't believe there's no dipstick... No problems though overall. I plan on changing about every 7-7.5k miles
#107
Oil change
Nice article and photos...Missing the last part..how to reset the oil service light.
#108
I know there is a video somewhere on here about it. If not you can simply just YouTube it
![]() #465420 National Capital Chapter My Progress Thread 2000 323Ci | TiAg | Gray | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE | |
#109
Sorry for double post, but does anyone know how many lbs of torque should be used to close the oil filter cap?
#110
Is not too much, something like 18 lb/ft, just hand tight it and make sure is reasonably tight and there's no leaks.
"If everything seems under control, you're just not going fast enough" -Mario Andretti. ___________________ River City Bimmers Chapter 2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta. 1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black. |
#111
thanks X3terrestrial, I thought it was 18lbs, because that's what it is on my e46
#112
Love these oil threads!
No car mntce. issue is debated with greater frequency or fervor than oil changes. Full Disclosure: I'm a daily visitor to a Porsche forum...things can get pretty ugly there.
Bottom Line: >Change oil + filter every 5K miles or annually, whichever comes first. >Use a top quality synthetic, and don't move up to a heavier weight oil unless you live in a hot climate or track your car. Our BMW engines, like those of other German luxury brands, are very complex (too complex?). Skimping on oil changes is a false economy for long term owners. relinuca |
#113
#114
Mike Miller from BMWCCA suggests 5,000 to 7,500. I shoot for 5,000 but my average over 16 oil changes has been closer to 6,000 as we're often on a long road trip when it comes due. I'm at about 99,400 on my 2009 (bought new) with virtually no issues whatsoever. Still looks brand new through the oil filler hole. I use nothing but BMW oil and filters. |
#115
#116
echelon - what ramps are those? I need to invest in a pair
#118
I hate to do this, but bump! I will be changing my oil this weekend
#119
Look on the instrument clusteryou will see 2 buttons in the lower centre part of the dash,
1) Make sure the ignition is swiched off, press and hold the left button and turn the ignition on to the first position keep holding the button down until you see the display change 2)Lift you finger and press and hold again untill reset appears ( normally after aprox 5 seconds ) it will also flash, once this happens lift your finger again 3) Then press and release straight away, this should reset the service indicator. I tried the above method to reset the service indicator after changing the oil and filter in my 2006 X3 diesel, but now I have a minus symbol in front of some numbers, does that mean I haven't done it correctly? I have tried numerous times but no change. Any help greatly appreciated! Last edited by Brynderwyn; 01-12-2013 at 09:47 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil change interval | kashrahman | E60 (2004 - 2010) | 11 | 03-22-2012 03:03 PM |
| Is my 4.8is a lemon??! | ZenX5 | X5 E53 (1999 - 2006) | 68 | 09-15-2007 08:08 AM |
| Post break in oil change | vadimv | E46 (1999 - 2006) | 10 | 01-30-2005 10:42 PM |
