BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
I have coded VIM and SAT and my oil sensors still work.
#27
+1 I have coded the crap out of my car and just successfully checked the oil level.
2012 535i, April build, Space Grey, Oyster Interior, 19" M sport rims/tires, premium pkg, premium sound, side/top cameras, heated seats, comfort access, ceramic controls, OEM spoiler, painted front reflectors, 35% tint, rear Fog lights, coded to my liking. |
#28
RUH ROH! The issue was definitely coding related. I did not troubleshoot this one by one to see exactly what coding was causing the issue; however, based on another user that contacted me, it seems it was ECO PRO coding related. I did not realize this before, but when it was coded and not working, there was an extra oil icon, the standard one a check mark, and a new one with a circle. Does anyone also have both of these Oil icons including the second one with the circle, and if so, is Oil Measurement working?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#29
Thanks for confirming. This is something they must have added after my build, and when I changed my production date, it appeared on mine, albeit with problems. Hopefully tomorrow they will still program my car with 2.47.5, and some of the issues like ECO PRO and the Oil Measurement System will work 100% when i change my Production Date again.
#31
.40 for programming and zero to open a puma case is the reason. F-10 vehicles are very time consuming when using ISTA/P.
As an update to this, I brought my car back in to the Dealer Monday, and they programmed it without any problems at all this time. Surprisingly, it was done with ISTA/P 2.47.7, which was just pushed to my Dealer on Saturday (No, I do not have 47.7 PSdZData yet).
Lessons learned:
#33
Great info. Thanks
#34
Shawn,
I think you are expanding the knowledge base the hard way! Glad the programming went through this time. |
#35
So long as I am not bricking any modules, I'll keep pushing the envelope though.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 10-12-2012 at 06:59 PM. |
#36
Thanks for the info.
2011 BMW F10 528i M Sport |
#37
Shawn, thank you for sharing your valuable experience in this fashinating field
#38
Is there a quick way to return everything to factory or do you have to go through every module? |
#39
#40
It's module by module, but just use your factory VO, and VO Code each module that was coded. It's simple and pretty fast to do it.
#41
Glad you got the programming done without a hitch this time...Now the wait for the 47.7 so you can code everything back again! You the man
#42
#43
TIA DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g. |
#44
For 6NR BMW Apps:
#45
OELSTAND_OENS = aktiv. I just need to test it now to confirm.
#46
If your car was built before 0312, and you use a >= 0312 Production Date, your Oil Level Measurement Screen will change an no longer work. To return it back to the original style, FDL Code OELSTAND_OENS = nicht_aktiv after VO Coding it. So, now I can continue to use a 0712 Production Date to VO Code CIC, and just set OELSTAND_OENS = nicht_aktiv when I am done, and all is well.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 10-20-2012 at 05:23 AM. |
