Old 10-17-2012, 07:47 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by mateforrest View Post
Thanks,
I just sent you an email for the FSC code.
Regards
Ok. I sent you the requested contact information.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 10-17-2012, 04:21 PM
mateforrest mateforrest is offline
Mein Auto: BMW F10 530D SILVER
Hello again Shawn
Please, could you give me more information about this:
VO CODE HU_CIC
VO CODE CMB_MEDIA
and also about this:
It assumes you know how to FDL Code, Modify your VO and VO Code.
I think i´m able to modify the VO (i have the pdf tutorial) but i´m not sure about FDL Code and VO code.
Also i have full working E-sys but i don´t know where i must to insert the pin 2960 for the first time.
Regards
Old 10-17-2012, 04:40 PM
Hello again Shawn
VO CODE HU_CIC
VO CODE CMB_MEDIA
Regards
The E-Sys - Getting Started Coding.pdf explains FDL Coding:
https://www.rapidshare.com/files/706...d%20Coding.pdf
Basically, you Read your FA (which is your VO), Activate FA, Read your VCM, Select and Read an ECU's CAFD, Right-Click on the CAFD and select "Edit FDL", change the Coding Data, and select "Code FDL"
This allows you to change individual parameters within an ECU.
The first time you invoke the FDL Editor (e.g. selecting "Edit FDL" or manually launching the FDL Editor), you will be prompted to enter your EST Token PIN.
VO Coding is the same, except instead of selecting an ECU's CAFD, Right-Click on the ECU itself (NOT the underlying CAFD in the Subfolder) and select "CODE".
This will code the entire ECU to a default condition based on the FA you have activated (primarily using the Production date and Option Codes), which may be the FA from the car that you Read, or it may be a modified version thereof that you have created, as will be the case here.
https://www.rapidshare.com/files/322...ries%20car.pdf
- BMWCCA #446923
- flick
Old 10-17-2012, 05:28 PM
Ok I think i understand the process,
but for example, for the LDW 5AD the process as i read is this:
KAFAS:
3000, TLC_START_VERSION, default_on
3000, TLC_ON_OFF, aktiv
3000, SEND_MESSAGE_327, aktiv
3000, SEND_MESSAGE_345, aktiv
3006, ACTUATOR_ON_OFF, aktiv
KOMBI:
3003, TLC_VERBAUT, aktiv
3004, ST_TLC_TIMEOUT, aktiv
3004, ST_TLC_ALIVE, aktiv
3004, ST_TLC_APPL, aktiv
HU_CIC:
3001, LANE_DEPARTURE_WARNING, aktiv
SZL_LWS:
3000, Lenkrad_Vibration, aktiv
but why not they do this?:
1º Add 5AD to VO of the car
2º VO CODE KAFAS
VO CODE KOMBI
VO CODE HU_CIC
VO CODE SZL_LWS
Regards.
Old 10-17-2012, 06:02 PM
KAFAS:
KOMBI:
HU_CIC:
SZL_LWS:
2º VO CODE KAFAS
VO CODE KOMBI
VO CODE HU_CIC
VO CODE SZL_LWS
Regards.
Amen brother. I have been preaching VO Modification and VO Coding for sometime, but some people are still unfamiliar with it, or are uncomfortable with it, or just prefer to FDL Code each and every parameter.
If it was me, I would just add 5AD to my VO, and VO Code the 4 affected ECU's.
In general, the only issue you may run into when VO coding that you won't while FDL coding, is that VO Coding takes into account the production date, whereas FDL Coding does not, so when VO Coding, one needs to make sure the VO Production date covers whatever production date the option being added was introduced. That though is not an issue here with LDW, as it has been an option on the F10 since its inception.
One other issue too is when you VO Code, you wipe out any previous FDL Coding you have done as the entire ECU is being set to a predetermined condition, so you would have to go back and re-FDL Code all you customizations. In the case of HU_CIC, that could be quite a bit, in which case it would be easier to just FDL Code the one parameter above, rather than having to recode 20 others after the VO Coding. Where VO Coding is truly advantageous, is when you do not know all the FDL Codes required to support an option, it will make them all for you.
- BMWCCA #446923
- flick
Old 10-18-2012, 06:43 AM
mrbombastic mrbombastic is offline
Mein Auto: 2012 535i
Amen brother. I have been preaching VO Modification anuction date the option being added was introduced. That though is not an issue here with LDW, as it has been an option on the F10 since its inception.
Thanks Shawn, great coding info... you're the best !!!!.
Old 10-18-2012, 01:47 PM
Hello Shawn,
I can retrofit the LDW whithout problems, take a look
I did via vo coding, and when finish enabled the option of always on because I don't have the button on my dashboard.
B
But i can't enable Internet, maybe for my vin number.
This is the previous state:
And after all the process Internet continue telling that is not available for my country, because the combox continues trying to access trough internal modem instead my iPhone.
Could you give further information about the change of vin number step by Step please. I'm afraid
Regards
Old 10-18-2012, 01:51 PM
Hello Shawn,
Attachment 346342
Attachment 346343
B
Attachment 346344
Regards
What are the last 7 of the VIN you attempted to use?
- BMWCCA #446923
- flick
Old 10-18-2012, 01:58 PM
I will send you by PM.
Is my real vin number.
I don't know how to use a fake VIN
Old 10-18-2012, 02:13 PM
I have responded in great detail to your PM; however, it is explained here in detail:
http://www.bimmerfest.com/forums/sho...5&postcount=45
- BMWCCA #446923
- flick
Old 10-19-2012, 08:33 AM
Please Shawn i need your help.
I follow rigorously your steps but I have a big problem, take a look:
Is like the unit losses its address and now I can do anything.
How can I solve it?
It's like it doesn't has CAFD line...
Thanks in advance for the help
Old 10-19-2012, 08:50 AM
Attachment 346430
Attachment 346431
Attachment 346432
How can I solve it?
Right-Click on CMB_MEDIA, select "New", and then navigate to your CAF Folder and select the corresponding .ncd file for CMB Media and insert it. Then select the added CAFD and Code FDL. The .ncd file name should be similar to CAFD_000005B6_004_002_110.
- BMWCCA #446923
- flick
Old 10-19-2012, 09:17 AM
Hello,
Please take a look to the pictures I don't have this options Click image for larger version
I can't load or make a new one.
I think I'm doing something bad.
Old 10-19-2012, 09:22 AM
Hello I could do it by detect CAF for SWE
But where I can put my actual vin
Old 10-19-2012, 09:24 AM
Attachment 346468
Yes, that was the next step. Just read your FA (which should have your real VIN), read VCM, and FDL Code the new CAFD.
- BMWCCA #446923
- flick
Old 10-19-2012, 09:36 AM
Ok now I have this,
One green and one red,
I'm waiting with the car switch of for a reset
Old 10-19-2012, 10:05 AM
Ok now I have this,
Attachment 346471
That is ok. Disconnect E-Sys and Reconnect. Only the Green one should remain.
- BMWCCA #446923
- flick
Old 10-19-2012, 10:36 AM
Thanks, i have the Comvox ok again.
But i try again to activate internet and live. i will do today yes or yes
This is your instructions :
1) FDL Code CMB_MEDIA / TELEMATIK_VIN = Coding_VIN
This means i must to do the code of the unit? Should i do first a read of the FA
2) Select Read FA, Save FA, and Edit FAok
3) In FA Editor under FAList, Expand FA, FZAuftrag, and Header, and right-click on Vinlong and select Edit and change VIN. You can use xxxxxxxxxxx, which has factory 614 and 615.ok
4) Save FA as FAKE_VIN.xml
5) Go to Expert Coding Module
6) Load FAKE_VIN.xml
7) Right Click on FA and select Activate
8) Read VCM
9) Read CMB_MEDIA ECU (should see you real short VIN in brackets)what do you mean? Right click read code, or Coding window Read coding data button, or Read CPS
10) FDL Code CMB_MEDIA ECUCoding window code button
11) Read CMB_MEDIA ECU (should see you fake short VIN in brackets)
12) Go to ConnectedDrive, Update Services and check BMW Live and Internet.
ok
After it is working:
1) Exit E-Sys
2) Launch E-Sys
3) Go to Expert Coding Module
4) Read FA
5) Right Click on FA and select Activate
6) Read VCM
7) Load FAKE_VIN.xml
8) Right Click on FA and select Activate
9) Read CMB_MEDIA ECU coding window read coding data?
10) FDL Code CMB_MEDIA / TELEMATIK_VIN = Most_VIN how can i do this?
12) Read CMB_MEDIA ECU (should see you real short VIN in brackets)[/QUOTE]
Best regards
Old 10-19-2012, 11:44 AM
Yesss!!!!
Finally I have it.
Problems with the recoding to my original vin
But where is BMW live ?
Thanks Shawn you are the best!!
Old 10-19-2012, 11:50 AM
This means i must to do the code of the unit? Should i do first a read of the FA Yes.
8) Read VCM
9) Read CMB_MEDIA ECU (should see you real short VIN in brackets)what do you mean? Right click read code, or Coding window Read coding data button, or Read CPS Right click ECU, Read Code. Any time you read an ECU, to the right of the ECU Name will be the ECU Address, and to the right of that will be the ECU VIN in brackets, (e.g. [C123456])
10) FDL Code CMB_MEDIA ECUCoding window code button Right click ECU, Read Code, highlight CAFD, select Colde FDL
ok
1) Exit E-Sys
2) Launch E-Sys
4) Read FA
6) Read VCM
9) Read CMB_MEDIA ECU coding window read coding data? Right click ECU, Read Code
10) FDL Code CMB_MEDIA / TELEMATIK_VIN = Most_VIN how can i do this? You had to FDL Code CMB_MEDIA / TELEMATIK_VIN in the very first step, there you set it to Coding_VIN before writing a Fake VIN to it, now you are returning it to Most_VIN so it uses youor real VIN obtained from the Most Bus. Right click ECU, Read Code, highlight CAFD, select Code FDL
Best regards
See my comment in above in Blue.
- BMWCCA #446923
- flick
Old 10-19-2012, 11:59 AM
Yesss!!!!
Finally I have it.
Attachment 346491
Attachment 346492
Ok. Glad I could help.
Did you add 6AL to your VO and VO Code CIC?
In any event, now just FDL Code HU_CIC / HU_NBT 3003 TELEFON_TELEMATIK_ONLINE / ONLINE_BROWSER_LIVE = aktiv.
Update Service afterwards (make sure you still have fake VIN in Combox when doing so)
After both are working, FDL Code CMB_MEDIA / 3006 TELEMATIK / TELEMATIK_VIN = Most_VIN, and DO NOT update your service again or you will loose everything.
- BMWCCA #446923
- flick
Old 10-19-2012, 12:25 PM
Yes i added 6AL to my VO.
Could it be the manufacture date of my car?
Is from November 2010. How can I change it?
Also can I code the radio preset and telephone guide in the HUD?
Regards
Old 10-19-2012, 12:29 PM
Regards
Production Date only matters when VO Coding. So, did you FDL Code ONLINE_BROWSER_LIVE = aktiv?
That should be all you need now.
As for your HUD, your car needs to have at least ISTA/P 2.47.x on it, otherwise you have to flash new firmware onto KOMBI. Go to Expert Mode, VCM, Click the VCM Master tab, and select Read under I-Steps. What do you show for I-Step (current)?
- BMWCCA #446923
- flick
Old 10-19-2012, 04:49 PM
This is my current I-step:
F010-12-03-500
Also as you can see in the next post i can active bmw live, but know the system try connect correctly but after a time says that internet start page is not available, try later.
Thanks.
Production Date only matters when VO Coding. So, did you FDL Code ONLINE_BROWSER_LIVE = aktiv? No, i code now as you told me, but trust me, my car has 6AL enabled on VO
yes you are right, my car doesn't has this entries:
Section 3000
- HUD_ENTERTAINMENT_ENABLE to aktiv (enables radio menu)
- HUD_TELEFONANRUF_ENABLE to aktiv (enables recent calls list to be displayed)
Old 10-19-2012, 04:54 PM
This is the pictures:
OClick image for larger version
