Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 10-14-2012, 10:21 AM
swatone swatone is offline
Mein Auto: 2001 740il
service engine soon light flashes then rough idle
I have a 2001 740IL....it runs fine then the service engine soon light flashes a couple of times then the engine idles rough especially at stops.....anyone had this problem before?
Old 10-14-2012, 11:59 AM
beemer1804 beemer1804 is online now
WAR MACHINE
Send a message via AIM to beemer1804 Send a message via Yahoo to beemer1804
Mein Auto: 95 740IL
Something is wrong, if it flashes then idle it could mean many things, you would have to run it through the computer, my guess is o2 sensor but thats just a guess, have it ran through the computer and let me know
War Machine
Old 10-14-2012, 12:28 PM
01740iLTony 01740iLTony is offline
Mein Auto: 2001 740iL
I had this same issue a few weeks back. I took to a local BMW shop and ask them to do a compute scan. The found the the rear coil that is connected to the spark plug was bad. Check out Bavarian autosports (www.BavAuto.com) for how to "do it yourself". I purchased everything on line from them also. It only took me about 1 hr to change the one coil and 8 plugs. Good luck.
Old 10-15-2012, 02:59 AM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
Never heard of the "service eng" light flashing. When the CEL flashes yellow that indicates a mis-fire. Is your CEL on?
Old 10-16-2012, 04:51 AM
First740i First740i is offline
Mein Auto: 740i
Check all your plugs and coils. Same thing happened to my car. Plugs were loose on the passenger. Also one plug was wasted.
Sent from my DROID4 using Bimmer App
Old 10-16-2012, 05:04 AM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Send a message via Skype™ to Dave 330i
Mein Auto:
I don't own a 7, but a 2001 330i. Yes, my engine service light has been on and off before, sometimes for some minor things. The current issue is with a vacuum leak, and the dealer wants to do a smoke test for $150, but credit its cost to the repair. Currently, the car runs great, so my philosophy if it is not broken, don't fix it still applies. If the engine has symptoms, then take it in for a check up. I think the dealer charges around $125 for diagnostic. Oh, running rough, most likely an air sensor or intake or exhaust valve sensor.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 10-16-2012, 12:08 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Why guess at what the problem is when you can easily find out by reading the OBD II codes.
If your CEL/SES light is illuminated/illuninating...it means that one of the sensors for the electronic emissions system has registered a fault. Since 1996 (in the USA) OBD II mandates have been in place for ALL car mfg's that sell vehicles here. Go have your car scanned (free in most states)...and post back what "P" codes you have. Or you can google "OBD codes" and find the information just as simple.
This may be something very simple to fix instead of letting go until more issues arise. It's a simple as hooking up an OBD II scanner/reader to your OBD port to find out what the issue is. Your car is trying to communicate with you to check your emissions system...do it and you won't have to "guess" what the problem is...your car will tell you were the issue is coming from.
The OP has no "location" listed...so if you live anywhere except California & Oregon (i believe)...you can take your car to any AutoZone/PepBoys etc and they will usually read your OBD II codes for free.
(Service Engine Soon (SES) & Check Engine Light (CEL)...are the same...BMW switched from CEL to SES mid production)
E38 OBD II port/connector
Q {BMW CCA Member #191509}
(SOLD)
Old 10-20-2012, 08:44 PM
Cangelo629 Cangelo629 is offline
Mein Auto: E38 2001 740iL
Get The Codes read..........Could Be Simple As Cleaning The Carbon Out Of Piedometer And Mass Chamber,,,,,,,,,,,,
