E60 (2004 - 2010)
Old 10-20-2012, 06:36 AM
bimmerrg bimmerrg is offline
Mein Auto: 535i
Radiator Area Noise Auxiliary Fan good/bad
I have been fighting with Dealer to check noise comes from front end after the car is driven for 20+ miles or so and when it is hot, stopped and restarted again with in 5 to 10 minutes.
Does it happen for all of you? A/C is also on at the start up. They say nothing wrong but I wanted to make sure before warranty runs out. Please let me know.
2009 535i Black Saphire Metallic/Natural Brown/Prem pkg, Sport pkg, comfort access, Navigation, Sport Transmission with Shift Paddles, PDC, Heated Front Seats, iPod and USB Adaptor, Satellite Radio, BSW Stage 1 Speaker upgrade, JBL MS8 DSP, Technic Harness and BMW Individual co-axial center speaker ==> Superb Custom LOGIC 7, New Michelin Pilot Sport A/S tires! Route 66 Extended Warranty till 5+yrs:1/26/2018 or 100k miles.
Old 10-21-2012, 08:47 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
What kind of noise, grinding, squeeling... A/C compressors usually start to make a mild grinding sound when they start to fail
and its usually the clutch. Does it do it with the A/C off? The 535 has so much going on up there however. So it could be a
variety of things. Oil cooler failures are common, but no known noises prior to. If its audible in the cabin with windows up
then it should be an easy fix for the dealer.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 10-21-2012, 11:19 AM
Mein Auto: 535i
Sounds like a hovercraft or airplane taking off. It happens with A/C on. Cool air comes though!
