BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#101
![]() As for the "internet start page is not available", that is NOT your car or coding, that is BMW's Portal. Sometimes it's unavailable. Not sure why though. F010-12-03-500 = ISTA/P 2.46.0, so you need the car updated or at the minimum KOMBI flashed with 47.x firmware.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#102
Thanks Shawn we did it Also i tried to use this code: HI_CIC - 3000 HMI - ECO_MODE = aktiv (Displays Efficient Dynamic Menu in CIC Nav menu) KOMBI - 3003 FZG - VERBER_HISTOIRE_ENABLE = aktiv (Enables fuel consumption histogram) KOMBI - 3004 ERM - CTR_HSTY_DISP_KI_APPL = aktiv (Enables fuel consumption histogram) But only the CIC fuel Consumption in the CIC Nav menu is working, the rest exist but is dummy. I think as you said in another post that is better :add option 4U2 to your VO and write it to the car. Then you would VO Code KOMBI, HU_CIC, JBBF, and IHKA. But i´m not sure how to change production data. Regards |
#103
https://www.rapidshare.com/files/322...ries%20car.pdf QUIT AFTER STEP 7. You do not need to, and should not, write this FA to the car. Just use it for VO Coding, but let the car store the original FA. What it does not explain is how to also change your FA Production date. For that, you need to change the FA Zeitkriterium field. You can only use dates that coincide with an actual Integration Levels (e.g. 0311, 0711, 0911, 1211, 0312, 0712). I am using 0712. If your car was built before 0312, and you use a >= 0312 Production Date, your Oil Level Measurement Screen will change an no longer work. To return it back to the original style, FDL Code OELSTAND_OENS = nicht_aktiv after VO Coding it. Make sure you read both of these posts first: http://www.bimmerfest.com/forums/sho...d.php?t=642231 http://www.bimmerfest.com/forums/sho...d.php?t=647622
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 10-20-2012 at 05:37 AM. |
#104
Hello Shawn,
I just do everything but the car of Efficient dynamics doesn't has animation. Please take I look: What do you think? Could it be because my car is diesel? Is possible that the 4U2 code is only for petrol engines? Another code for diesel? Regards |
#105
What VO Date did you use and what ECU's did you VO Code?
#106
Jbba, ihka clima, cic and kombi
Vo date 09/11. Also I finished after step seven as you advice me the vo coding, and when I connect esys and read now FA shows 09/11 What's unit is Jbba? Gear shift? Regards |
#107
Maybe VO Code these too: GWS = Gear selection switch EGS = Electronic Transmission Control Unit DME = Digital Motor Electronics (Car CAN NOT be Running - Just Auxiliary Power) I would use a VO Date of at least 0312, which means you will have to go back and FDL Code HU_CIC / OELSTAND_OENS = nicht_aktiv afterwards.
#108
Shawn i think that it could be because my car has IHKA unit and also rear climate control unit (i have the option of high 4 zone climate contro), what do you think? Regards |
#109
No. Did you use a 0312 date like I said?
#110
Guys, sorry for a dumb question.
I've got UK 2011 car with all options except 614 (Internet), it was simply not available to order in march 2011 The question is short. Is it possible to continue to use Assist services (most valuable is google "send to car") but to force browser to use BT tethering? Or the only way to enable browser is to lost all my assist services? I've tried to enable "Internet" option but there is a message "Internet is not available in your country" (as this option is not enabled for my car VIN on the BMW servers) Thank you! |
#111
#112
Ok, thank you.
The last question - as I've got all hardware, and the limitation is purely software (on the BMW side), Internet is available in the UK officially, is it possible to work-around "internet is not availible" somehow? Or the only way is to fully switch to BT connection? |
#113
#114
It is not a problem to pay, the issue is that officially the retrofitting of 614 is not possible (silly...)
It's a pity. |
#115
You can try though. I am curious to know myself.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 11-02-2012 at 06:52 PM. |
#116
614 option is added (I've got "Internet" menu available)...
I activated the Assist service before 614 was coded, it is possible that the information is stored somewhere? |
#117
I would just call them and tell them you have Internet Option 614, and would like to subscribe to Internet Services. At worst, they can just say they checked, and your car isn't capable, at which point I would then volunteer that you retrofitted 614, and the car has been properly programmed, and see if they will do it then. You have nothing to loose.
#118
Hello, I have a E90 LCI 10/2010 with S606A NAVIGATIONSSYSTEM BUSINESS . Is it possible to run the Internet via Mobile Phone in Poland? I have only d-can cable and
I have experience in coding by ncs expert. My options: S606A NAVIGATIONSSYSTEM BUSINESS S612A BMW ASSIST BMW Assist S615A ERWEITERTE BMW ONLINE INFORMATION S616A BMW ONLINE S633A HANDY VORB. BUSINESS/BLUETOOTH-SCH. S698A AREA-CODE 2 S6AAA BMW TELESERVICES S6ABA STEUERUNG TELESERVICES S6VCA STEUERUNG COMBOX S854A SPRACHVERSION FRANZOESISCH S863A SERVICE KONTAKT-FLYER EUROPA Now i Have only BMW Online and when i try to connect i see the message "Homepage unavailable" Is this possible? Last edited by gumes; 11-16-2012 at 01:38 AM. |
#119
Being in Poland won't matter, because once you change your Combox VIN, your car appears to be in the country of the donor VIN's country.
#120
No, not the modules, just the Vehicle Order (FA), and then VO code the affected modules (HU_CIC and CMB_MEDIA).
#122
In summary: 1. change vin with tool32 in CMEDIAR.prg 2. -$633 -$612 +$614 +$644 3. ONLINE_BROWSER = beide_aktiv 4. TELEMATIK_VIN = Coding_VIN Such a procedure? |
#123
Use Tool32 CMEDIA.prg, job C_FG_SCHREIBEN to change the VIN. I believe with this method you need the extra Checksum digit at the end. +6AL also if you want BMW Live. Coding as follows: HU_CIC: CONNECTED_DRIVE = aktiv ONLINE_BROWSER = beide_aktiv ONLINE_BROWSER_LIVE = aktiv (if also +6AL) ONLINE_SERVICES = aktiv ONLINE_SERVICES_GLS = aktiv CMB_MEDIA: SIM_ENABLED_MB = csim DATACOMM_CSIM = aktiv DUN_PROFILE = aktiv
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 11-16-2012 at 02:54 AM. |
#124
my files: http://ghosting.home.pl/mcic.txt http://ghosting.home.pl/media.txt |
#125
Try it without them then.
