E34 (1989 - 1995)
Hello!!!
#5 fuse keeps blowing Dashbord light is out Front parking light is out Rear parking light is out Now I am going to blow my brains out !!! I have replaced all the bulbs in the dash cluster (cluster works) front right and back right. Directionals work parking lights dont. I replaced the headlight switch and dimmer switch on the left side of the dash. What Gives ? |
Possiable your wattage has increased ,reversed connection at a lamp,possible damaged socket would do it too.
Start a careful examination of ALL the parts you touched.
If its not any of the above then you need to see if you have the correct bulb in the front indicator.
If it is a single contact bulb it will short the two contacts in the socket and blow the fuse like you say. |
